Turbo Rebuild DIY
Old Mar 7, 2006 | 12:55 PM
tecni's Avatar
tecni
Default Turbo Rebuild DIY
So my Greddy TT's Blew and people keep telling me I gotta spend $$$$ to rebuild them (atleast 275 each) if I send them to turbochargers.com.
However I found the rebuild kit on ebay good for most mitsubishi turbos and mix that with some ***** and you have a turbo DIY. (I also had borrowed some advice from this site:
http://www.vfaq.com/mods/Turbo-rebuild.html
Rebuilding a turbo is NOT a big deal people! We ofter listen to shops telling us everything is soooooo complicated and how only a machine shop or a true expert can do it. I'm tired of getting on this forum and not finding good DIY's.
Here's some pics of my preliminary rebuild. Basically all I did is un-seize the turbo blades and re-oil the whole setup with manual tranny lube.
There is a plate that sits under the exhaust fan that collects alot of crusty oil. Called Coking... You get alot of this when you shut your car off immediately after running it. I have yet to figure out why mine had this issue in the first place, considering I always let the greddy auto timer run its 1+ min cycle.
ANyways, this plate must be cleaned thoroughly as the website indicated. Don't be fooled by what it says. THey make it seem like its easy to remove this stuff but I let it soak in brakleen for over an hr and it was just as bad when I took it out. I recommend using 400 grit sand paper or a sanding bit on a dremel to remove this gunk.
Use a relatively dust-free environment and use lots of lube. Careful not to break any seals. Its hard to mess it up unless you drop a turbo blade or something.
Good luck to all willing to take on the challenge.
Oh yeah, here's a few pics of the disassembly and reassembly.
Old Mar 7, 2006 | 01:09 PM
theking's Avatar
theking
You really need to get them balanced as well.
Old Mar 7, 2006 | 01:16 PM
Zilvia's Avatar
Zilvia
yeah.........
Old Mar 7, 2006 | 02:02 PM
tecni's Avatar
tecni
yeah I was reading up on that... Duely noted!
Old Mar 7, 2006 | 02:23 PM
MIAPLAYA's Avatar
MIAPLAYA
The major thing as mentioned before is having the turbo re-balanced. Without this you may be rebuilding them again sooner then you would want to.
Old Mar 7, 2006 | 03:43 PM
Eazzy's Avatar
Eazzy
Interesting but stands to reason. I take it that the turbine or in the case of a Turbo ---Turbines have to be balanced on the shaft as an assembly then location in relation(turbine to Shaft) be marked so when it goes back together as it was balanced. Although I suppose they are keyed. ??????
Old Mar 7, 2006 | 06:36 PM
tecni's Avatar
tecni
well if you look at the blades, they are completely symmetrical but on the exhaust side, there's an asymmetrical screw that I believe throws the balance off a little bit and since a turbo spins at ridiculous rpms (like 80,000) it can wear uneavenly or explode into little fragments. Hence it needs to be balanced.
Old Mar 7, 2006 | 06:46 PM
Eazzy's Avatar
Eazzy
Thats a given. Even if it is put back exactly as it came apart,, the fact is micoscopic abrasives in the air knocked things out of balance before the tear down and as u say 80,000 - 100,000 plus RPMs leaves no margin for error. Im running Vortech but most my installs are TNs---I also do installs on diesel Pick-Ups and PowerStroke work. Im paying like 900.00 now for the PowerStroke Turbos
Old Mar 8, 2006 | 06:47 AM
supra crazy's Avatar
supra crazy
Hey what website are you refering yo when you say as the website indicated the only website you posted was one of diagrams of vaginas? also put a not worksafe stamp on this .
http://images.google.com.co/imgres?i...ial_s%26sa%3DG
Old Mar 8, 2006 | 06:58 AM
theking's Avatar
theking
LOL. Never went to that page. What were you looking at before you posted this thread????
Old Mar 8, 2006 | 07:04 AM
Eazzy's Avatar
Eazzy
Holy S**t ---That is not the proper enviourment to be working on turbos. Although it was educational.
Old Mar 8, 2006 | 07:12 AM
st350z's Avatar
st350z
keep posting, want to know how it turns out
Old Mar 8, 2006 | 09:50 AM
tecni's Avatar
tecni
Sorry guys... My ex g/f had sent me that link and I guess I must have switched them around when I was copy/pasting LOL.
I just fixed it.
Its: http://www.vfaq.com/mods/Turbo-rebuild.html
No its not the best environment to be working on a turbo but I didn't really care too much because they're coming apart again as soon as the seals come in and then I'm taking the project indoors and away from dust.
Turbochargers.com charges 50 bucks to balance them. Its hard to believe there's only 4 shops in the nation that can balance a turbo!?
Old Mar 8, 2006 | 09:52 AM
MIAPLAYA's Avatar
MIAPLAYA
I just fixed it.
Well you have to have a VSR to balance them and they aren't cheap. Turobnetics has three.
Old Apr 30, 2006 | 05:58 PM
tecni's Avatar
tecni
Redat of North America does turbo rebuilds at a very reasonable price. Check them out. They have a warehouse/shop here in Orlando.
350Z_Al
Oct 29, 2020 07:44 PM
