Bov
Old Mar 23, 2006 | 06:18 AM
Jason333's Avatar
Jason333
hi
My TN raptor flutters, and everyone i have heard in video's flutters. I talked with MIAPLAYA and looked at the tighness of his pics..looked the same as mine.
Old Mar 23, 2006 | 06:20 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Jason-I adjusted mine a little tighter than I had it in my dyno video(according to MIA's pic) and I think it sounds cleaner now....only takes 1 min to adjust set it to how you like.
Old Mar 23, 2006 | 06:46 AM
MIAPLAYA's Avatar
MIAPLAYA
Exactly...very minor changes to the tensioner can change the sound drastically. The key is to adjust it so that it does not flutter at all and ensure you have no compressor surge at the same time..
Old Mar 23, 2006 | 10:04 AM
Jason333's Avatar
Jason333
hi
When i get home ill tinker with it a bit. Thnx guys!
Old Mar 23, 2006 | 03:48 PM
Jason333's Avatar
Jason333
hi
Just went from pretty tight to pretty loose, and it still flutters.
Old Mar 23, 2006 | 03:51 PM
350Zylow's Avatar
350Zylow
Rfl.
Old Mar 23, 2006 | 07:05 PM
andypandy's Avatar
andypandy
Originally Posted by booger
Andy
The BOV on a Vortech SC is a Bypass valve . It is open under vacuum and closes when vacuum drops to a adjusted level and opens again when your off the gas and vacuum comes back
same with all blow off valves... no? all blow off valves are opened via vacuum in the intake manifold/plenum through a vacuum line. that's how i changed my APS bov to SARD r2d2 bov to HKS SSQ bov. now i can switch to whatever i want, depending on my mood for sound!
APS had heavy flutter... switch to SARD for mediocre psh and a slight flutter at low boost... then to HKS for a very strong whistle to wake up bums at the side of the street.
Old Mar 24, 2006 | 08:53 AM
Jason333's Avatar
Jason333
hi
I just called Reggie at TN and he said the BOV will have a little flutter to it, so im gonna set it to about 6 threads showing and let it go at that.
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
