Bov
Old Mar 22, 2006 | 11:12 AM
mpaige22's Avatar
mpaige22
Question Bov
Quick question....I have heard a bunch of different BOV's and the noises they make. How come some give off a Pshhhhhhhht sound and others sound more like a pssssst (whistle) sound? Which ones are which? aka brands
Old Mar 22, 2006 | 11:39 AM
mpaige22's Avatar
mpaige22
bump for an answer
Old Mar 22, 2006 | 11:42 AM
jcarp's Avatar
jcarp
brands and psi
Old Mar 22, 2006 | 12:13 PM
mpaige22's Avatar
mpaige22
Is it the higher the PSI the more of a whistle?
Old Mar 22, 2006 | 12:25 PM
taurran's Avatar
taurran
That depends on the brand. I guess it would be easier if you let everyone know what sound you're looking for.
Old Mar 22, 2006 | 12:49 PM
Phaneom's Avatar
Phaneom
I like this brand, sounds cool Check out the link
http://videos.streetfire.net/search/...62DAE06131.htm
Old Mar 22, 2006 | 12:50 PM
andypandy's Avatar
andypandy
it all depends on the design of the outlet flange.
the HKS SSQ has a tri-fin design which induces a whistle sound. the outlet is very tiny, so the velocity of the discharge is very quick. with the quick gust of air plus the tri-fin design, the bov emits a sharp whistle noise.
the SARD r2d2 has a medium sized outlet which induces the common 'pssht' sound. there are no gimmicks to manipulate the discharged air, so the noise in general is the common psht. the blitz and greddy bovs both emit similar sounds.
booger's Avatar
booger
Are you talking about a BOV on a turbo or a Supercharger ?
Old Mar 22, 2006 | 12:53 PM
andypandy's Avatar
andypandy
a BOV should be universal as it would work perfectly identical on a supercharger or a turbocharger system with an inlet duct to the throttle body.
Old Mar 22, 2006 | 01:25 PM
mpaige22's Avatar
mpaige22
I was inquiring about the sound for a TT. Helpful input though fellas. Thanks.
Old Mar 22, 2006 | 01:26 PM
mpaige22's Avatar
mpaige22
mpaige22's Avatar
mpaige22
Old Mar 22, 2006 | 01:27 PM
mpaige22's Avatar
mpaige22
mpaige22's Avatar
mpaige22
Old Mar 22, 2006 | 01:40 PM
booger's Avatar
booger
Andy
The BOV on a Vortech SC is a Bypass valve . It is open under vacuum and closes when vacuum drops to a adjusted level and opens again when your off the gas and vacuum comes back
Old Mar 22, 2006 | 01:48 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
what about the BOV´s that make a kind of fluttering noise?
Old Mar 22, 2006 | 02:32 PM
Alberto's Avatar
Alberto
Cranky FI Owner
When they are set to loosely, they will release air in a flutter-meaning more than 1 clean psshhh. Mine did that, I just tightened it up a few rotations and sounds much cleaner to me...
Old Mar 22, 2006 | 03:01 PM
Dirty Dave's Avatar
Dirty Dave
Yea fluttering is not good. Can lead to compressor surge killing the life of the turbo.
Old Mar 22, 2006 | 06:46 PM
Nitrouz's Avatar
Nitrouz
Back to Z
my HKS SSQV makes the high-pitched "pssssst" sound...and it's really loud compared to the stock APS bypass valve.
Old Mar 22, 2006 | 08:38 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I thought the APS bov make fluttering noise and that's normal. Watched many APS ST, TT videos and they all flutter. Is this normal or what on APS?
