Seriously,horsepower limit with the APS kit?
Old Apr 12, 2006 | 11:36 PM
  #61
marluci7's Avatar
marluci7
Originally Posted by Gman2004
what are you doing to prevent "head lift" if it's even that what everyone is experiencing? Are you sleeved? what head gaskit are you using? and what size studs?
Im not sleeved... .I use ARP head studs.. I dont know what size they are.... I dont have any issue's with the car... When i race.. i redline third , fourth and fifth!!!!! It is crazy...
Old Apr 13, 2006 | 12:35 AM
  #62
z33boi's Avatar
z33boi
Hey don't mean to hijack this thread but hey marluci7, hows your JWT clutch holding up to all that power? do you ever race at 40mph and does it ever slip?
Old Apr 13, 2006 | 12:37 AM
  #63
marluci7's Avatar
marluci7
clutch is fine... I have zero traction at 40.. I go from 60 all the time....
Old Apr 13, 2006 | 12:53 AM
  #64
calimarc's Avatar
calimarc
Marin who did you go with for an upgraded driveshaft?
Old Apr 13, 2006 | 07:23 AM
  #65
marluci7's Avatar
marluci7
My driveshaft is original.....
Old Apr 13, 2006 | 07:01 PM
  #66
calimarc's Avatar
calimarc
ahhhhhhhh....that is why there will be no going from a dig!
Old Apr 13, 2006 | 07:19 PM
  #67
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Why do you say that?? Performance motorsport ran their car into the low 10s on the stock 6-speed, driveshaft and rear end. All they did was run DSS axles. No one that I know of has broken the stock carbon fiber driveshaft on a 350Z.
Old Apr 13, 2006 | 08:36 PM
  #68
G352NV's Avatar
G352NV
1g broke his on the dyno.
Old Apr 13, 2006 | 08:48 PM
  #69
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
interesting place to break a driveshaft considering there's no hard shifting and most dynos aren't load based. Was it on a load based dyno?
Old Apr 13, 2006 | 08:49 PM
  #70
G352NV's Avatar
G352NV
Yes and from I heard he was at 480hp at the time with a auto.
Old Apr 13, 2006 | 09:02 PM
  #71
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
that sounds very weird...I would have to suspect that the driveshaft was damaged in some other way before it broke on the dyno. There are guys making A LOT more power than that and shocking the $hit out of the driveshaft with no issues at all.
Old Apr 13, 2006 | 09:12 PM
  #72
AmyCroft's Avatar
AmyCroft
Smile Just One and a reason
Jeff ( 350NOW ) lost a shaft due to an rubbing of an aftermarket - JDM exaust
kit that got pushed into the driveline after his brother ran over something.
If the outer shell is scored or damaged in a small way it will come apart.
The manual say's during R/R if the driveline falls in the shop it should be replaced.
Cheers Amy -
Old Apr 13, 2006 | 09:17 PM
  #73
G352NV's Avatar
G352NV
Maybe 1G will have more info.
Old Apr 14, 2006 | 09:35 AM
  #74
1G''s Avatar
1G'
Yeah Scott said it must have been damaged. that thing is Carbonfiber and strong as hell.
So i think it was either a defective one or some type of damage happen to it?!?
Old Apr 14, 2006 | 12:12 PM
  #75
calimarc's Avatar
calimarc
Sorry...meant to say axels instead of driveshaft. Sometimes I get my axels mixed up with my driveshafts
Old Apr 14, 2006 | 05:39 PM
  #76
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
ah...makes much more sense now
Old Apr 14, 2006 | 07:24 PM
  #77
calimarc's Avatar
calimarc
Was worried that I was going to be featured in your "QOUTE OF THE WEEK"
Old Apr 15, 2006 | 04:51 AM
  #78
Philthy's Avatar
Philthy
Boost Junkie
I'm guessing that you're not anywhere near 600-700whp, and/or they used either 1/2 head studs or L19 7/16 studs and added additional clamping force.
Question, are you really running Meth and 100 octane fuel?
Old Apr 15, 2006 | 06:30 AM
  #79
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Only idiots are featured there.
Old Apr 15, 2006 | 10:26 AM
  #80
calimarc's Avatar
calimarc
Do you ever worry that u will run out of them?
