Stillen Stage 4 keeps killing plugs
Old Apr 14, 2006 | 10:15 AM
Alberto's Avatar
Alberto
Cranky FI Owner
^Even rich they can detonate, timing is also critical. Ive heard they run rather aggressive timing but have no experience with those units myself.
Old Apr 14, 2006 | 12:20 PM
cersoft's Avatar
cersoft
Originally Posted by Dr.G
that's what i have , i had them for stage 3 and now same ones for stage 4, i drove around 16K on them no probs. Detonation is rare with Stillen since they tend to run rich, maybe your gas is not good, do you always fill up at the same place with same type of gas?
I do fill up at the same place always with Chevron 92 octane ...
Old Apr 14, 2006 | 12:24 PM
chimmike's Avatar
chimmike
you can't get 93 octane there?
Old Apr 14, 2006 | 12:48 PM
nateg35's Avatar
nateg35
I copied this from another thread
http://www.evanscooling.com/main21.htm
Old Apr 14, 2006 | 02:56 PM
cersoft's Avatar
cersoft
So, after talking to stillen they have confirmed that the plugs that I am using are ok, also, yes detonation is occuring, and they suggested that I check the intercooler pump and that my MAF is not dirty. A dirty MAF will mean that fuelling from the 7th injector is fine because it is based off of boost but the other 6 will be not working correctly.
So, I'll have a look at both of these issues and see what happens ...
Colin
Old Apr 14, 2006 | 03:21 PM
rookie's Avatar
rookie
Which cylinder is it? Is it the same cylinder?
Old Apr 14, 2006 | 03:23 PM
cersoft's Avatar
cersoft
First time it was #3 (passenger side middle), second time it was #1 (passenger side front)
Colin
Old Apr 14, 2006 | 03:32 PM
rookie's Avatar
rookie
I know you did a dyno when you upgraded. Did you see the A/F? You may want to consider putting the stage 3 pulley back on while using the stage 4 pump/injector/map. At least until you get things sorted.
Old Apr 14, 2006 | 03:44 PM
cersoft's Avatar
cersoft
After I put on the stage 4 I was running about a point richer...
Old Apr 14, 2006 | 03:50 PM
rookie's Avatar
rookie
Thru the whole power band or peak? If it's the whole power band, I don't know what to say. If they confirm you were detonating even at stage 3 something else could be wrong. How many miles are on the coils?
Old Apr 14, 2006 | 03:54 PM
cersoft's Avatar
cersoft
Yeah, through out the whole range .... there are 23k on the coils and there is no real way to confirm that I was definately detonating on stage 3 because I never had any issues ....
Old Apr 14, 2006 | 03:58 PM
G3.5T's Avatar
G3.5T
I have those same plugs in my set up. They were supposed to be pre gapped but the gaps were not all identical. I bought a gapping tool and gapped mine all down to. 040. No misfire or missing thus far.
Old Apr 15, 2006 | 04:42 PM
cersoft's Avatar
cersoft
Further information, I got on it today and then the noise (that we are assuming is detonation) occured, I glanced down at my A/F meter and it said 11.5 ... This is really confusing and starting to **** me off ....
Colin
Old Apr 15, 2006 | 04:49 PM
theking's Avatar
theking
It's probably your timing then. Having a good AF ratio doesn't insure that knock isn't happening.
Colin
Old Apr 15, 2006 | 04:51 PM
brutaleboy's Avatar
brutaleboy
Colin
Please keep us the updates...thanks
Old Apr 17, 2006 | 02:05 PM
cersoft's Avatar
cersoft
So, is there anyway that either the crank signal can get mis-read or offset somehow ...
One other point, I have switched over to Shell gas and it has not detonated today so far, but I am getting a little belt slip that I need to look into ...
Colin
Old Apr 17, 2006 | 08:14 PM
rookie's Avatar
rookie
Do you have a boost gauge? If the split second box was getting the wrong or a bad signal I think it would pretty much go crazy and throw the system into limp mode.
You're in Seattle any weather coorelate to this? Would the SS or ECU be getting wet? (shot in the dark) Are you running any kind of Technosquare flash?
Old Apr 18, 2006 | 04:14 PM
  #38
cersoft's Avatar
cersoft
Ok, so, the Shell gas made no improvements, still detonation, AND now when I change up gears I.e. High RPM in 2nd and change hard and floor it then there is not the kick in the pants that I used to get ....
I'm totally gonna strip this thing down on thursday and see what the hell is going on ...
Colin
Old Apr 18, 2006 | 04:20 PM
  #39
rookie's Avatar
rookie
AAM demo'd the cipher program to some FXers. They liked it for the timing control. Maybe it would be useful in your situation.
Albertos thread https://my350z.com/forum/showthread....17#post2311017
Old Apr 18, 2006 | 04:39 PM
  #40
cersoft's Avatar
cersoft
Yeah, that looks really cool, it would definately help me to figure out if it's an intake temp thing or a timing issue, might just have to jump on that ...
Colin
