Stillen Stage 4 keeps killing plugs
Old Apr 13, 2006 | 08:57 AM
cersoft's Avatar
cersoft
Default Stillen Stage 4 keeps killing plugs
So, for those of you that read my other engine missing thread you'll be somewhat up to speed.
Last week my engine developed a very bad miss on cylinder 2, we took the spark plug out and found that it has welded itself together, so, new plugs all around.
Now a week later, the problem is back, engine is definately missing on one of the cylinders. Now of course it could be the coil pack for #2 but it is more than likely another dead spark plug.
Do you guys think I should go to 2 steps colder plugs and see or do you all think that there is a greater problem here.
Thanks in advance,
Colin
Old Apr 13, 2006 | 09:26 AM
nateg35's Avatar
nateg35
Hey cersoft...Have you check with Stillen ?
Old Apr 13, 2006 | 09:28 AM
cersoft's Avatar
cersoft
Have you ever tried to get through to those guys ..... yes, I have left a message ...
If anyone has any inside, straight to the source numbers then that would be appreciated ...
Colin
Old Apr 13, 2006 | 09:51 AM
rookie's Avatar
rookie
714-540-5566 ext 121 takes you straight to service manager.
Old Apr 13, 2006 | 09:57 AM
cersoft's Avatar
cersoft
Thanks, yeah, I called Sam and left a message ...
Old Apr 13, 2006 | 12:11 PM
nateg35's Avatar
nateg35
Please keep us posted of what you find...how long have you been running on stage 4?
Old Apr 13, 2006 | 12:14 PM
chimmike's Avatar
chimmike
Iridium plugs, what's your gap? 1 step colder should be fine unless that stage 4 setup is running serious timing..........
Old Apr 13, 2006 | 12:37 PM
cersoft's Avatar
cersoft
I'm pretty sure that the iridiums are pre-gapped, still waiting to talk to stillen ...
Colin
Old Apr 13, 2006 | 02:26 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Colin
what type plugs you running.if its the same cylinder its prolly a coil pack for that cylinder.
Old Apr 13, 2006 | 02:47 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Run platinum gapped at .035...1 step colder of course.
Old Apr 13, 2006 | 02:50 PM
cersoft's Avatar
cersoft
Yeah, I'll figure that out when I go to see my mechanic later today ... I know that I had the NGK iridiums one step colder before but I'm not 100% sure which plugs are in there now.
Talked to Stillen and they think it's detonation, if it is then I had it while I was stage 3 also ...
cersoft's Avatar
cersoft
What is the difference between the iridiums and platinums ??
Old Apr 13, 2006 | 03:30 PM
nateg35's Avatar
nateg35
sorry if this question sounds stupid but what's the cause for detonation...is it the A/F too lean?
Old Apr 13, 2006 | 05:00 PM
chimmike's Avatar
chimmike
I gap my iridiums at .035" with no issues running 10psi TN kit.
detonation can be from intake temps being too high, not necessarily from a lean condition, but yes, that's the most common cause.
Old Apr 13, 2006 | 06:25 PM
cersoft's Avatar
cersoft
So, it turns out that the plugs that were in there are NGK PLFR6A-11 are these right ??
Old Apr 13, 2006 | 06:48 PM
Beer Goggles's Avatar
Beer Goggles
So you had detonation before and didn't find out why?
Old Apr 13, 2006 | 09:36 PM
cersoft's Avatar
cersoft
That's the point, I was never sure that it was detonation, we always assumed that it was hi-flow cat's material resonating, this is because it started without any mod changes ...
And yes, in hindsight I should have investigated more ...
Old Apr 13, 2006 | 10:39 PM
nateg35's Avatar
nateg35
did you upgrade from 2 to 3 right...did detonation happen then?
Old Apr 14, 2006 | 08:54 AM
superchargedg
Damn Noobs
yep those are the right part #,s.i just pulled one out and its the same.
Old Apr 14, 2006 | 10:11 AM
Dr.G's Avatar
Dr.G
that's what i have , i had them for stage 3 and now same ones for stage 4, i drove around 16K on them no probs. Detonation is rare with Stillen since they tend to run rich, maybe your gas is not good, do you always fill up at the same place with same type of gas?
