Built Sleeved Long Block - Thanks Kyle & Import Parts Pro
Old Apr 13, 2006 | 04:51 PM
Yancy's Avatar
Yancy
Default Built Sleeved Long Block - Thanks Kyle & Import Parts Pro
Just some some eye candy of my new long block that was built by Import Parts Pro. Thanks Kyle.
Attached Thumbnails Built Sleeved Long Block - Thanks Kyle & Import Parts Pro-sb2.jpg   Built Sleeved Long Block - Thanks Kyle & Import Parts Pro-sb3.jpg   Built Sleeved Long Block - Thanks Kyle & Import Parts Pro-sb4.jpg   Built Sleeved Long Block - Thanks Kyle & Import Parts Pro-sb5.jpg
Old Apr 13, 2006 | 04:52 PM
Yancy's Avatar
Yancy
Default Few more
Few more. Here's what going in the Z in the next couple of weeks.
Wiseco Forged Pistons 8.8:1 CR (.020 over with ceramic coating on skirts and tops)
Eagle Forged Rods
ARP Rod Bolts
ARP Head and Main Studs
Cometic Head Gaskets
Darton Sleeves
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Rod and Main bearings
JWT S1 Upgraded Cams
JWT Heavy Duty Valve Springs
Heads oil passages cleaned
Heads redecked
Ported exhaust and intake runners
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
New OEM Nissan Oil Pump
ATS triple carbon clutch, ATS carbon LSD with LSD oil, DSS level 2 1/2 axles, Greddy Radiator Breather Tank, 750cc injectors, Utec, Koyo Radiator, Samco hoses, Greddy oil catch tank, AAM oil pan spacer with AAM return lines, Crawford Plenum, SVRT 3 inch exhaust with w/g dumps.
Attached Thumbnails Built Sleeved Long Block - Thanks Kyle & Import Parts Pro-sb1.jpg   Built Sleeved Long Block - Thanks Kyle & Import Parts Pro-sb6.jpg
Old Apr 13, 2006 | 05:40 PM
overZealous1's Avatar
overZealous1
Sweet!!! now your gunna have all sorts of speeds!!
Old Apr 13, 2006 | 06:20 PM
theking's Avatar
theking
Everyone be sure to check their blocks when they get them back from Darton(if they sleeved it with their machine shop). They've been mixing up blocks lately.
Old Apr 13, 2006 | 06:23 PM
Yancy's Avatar
Yancy
Thanks for the heads up to everyone. My block was sleeved in Texas by a shop that has sleeved several others before mine. How are they mixing them up?
Old Apr 13, 2006 | 06:38 PM
theking's Avatar
theking
Sending the wrong ones back. I guess they don't understand the headache we have to go through for bearings!!!
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
nanotech
Oct 2, 2015 05:02 AM
35reilly
Sep 28, 2015 07:42 AM
