UTEC with TS Reflash on TNetics Kit
Old Apr 16, 2006 | 04:06 PM
NETSHARK's Avatar
NETSHARK
Default UTEC with TS Reflash on TNetics Kit
I wanted to ask you guys, in UTEC manual they wrote you can not use the stock mode on utec if you changed your injectors, this will also applies on turbonetics cars because of injectors upgrade ?
what will happen if i turned the remote switch to stock mode on UTEC in a Turbonetics Turbocharged Z with TS Reflash ?
Old Apr 16, 2006 | 06:28 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
In map zero, your factory ECU will control everything, and the UTEC is out of the picture. Since you have a reflash for your turbonetics kit, then your engine will run exactly as it used to.
Old Apr 17, 2006 | 06:37 AM
NETSHARK's Avatar
NETSHARK
Thank you Sharif, but its written in UTEC manual: don`t use stock mode if you upgraded your injectors, why ?
Old Apr 17, 2006 | 06:39 AM
MIAPLAYA's Avatar
MIAPLAYA
Because they are assuming a stock ECU flash running larger injectors which would not work right. With the Turbonetics flash scaling the 380s the way it does it shouldn't matter.
Old Apr 17, 2006 | 06:43 AM
Sharif@Forged
Forged Performance
Exactly correct.
Old Apr 18, 2006 | 02:22 AM
NETSHARK's Avatar
NETSHARK
Thank you guys so UTEC is on the way !!!
Old Jun 29, 2006 | 03:56 PM
down_shift's Avatar
down_shift
Not working for my setup right now... Running insanely rich (almost drowning out the car).. someone send me their parameters!
2ndchanceZ
Oct 26, 2015 08:03 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
