Which Cams ?
Old Apr 23, 2006 | 11:18 PM
dscheers's Avatar
dscheers
Thanks, do you have an URL for me to check it out?
I have 3 set of cams: stock ones, JWT spec ones and then Tomeis... don't really think of getting yet another set (unless they blow the others away!)
Danny
Originally Posted by Bullitproof
i got that number from the box.... and i i'm fairly sure my installer got that number from Ted also. these are true f/i cams. the other ones are n/a cams that work well with f/i cars. scotts performance kept the duration down, the overlap to a minimum.....here's your choice. i'm not sure if you have to shim the jwt's but i'm pretty sure you have to with the tomei 268's. scott's cams a hollow too!!! i'll let you guys know what kind of numbers i get with these cams after tuning.
Old Apr 23, 2006 | 11:26 PM
G352NV's Avatar
G352NV
Originally Posted by bigbri
Scott makes more than 1 FI cam bro...there are 3....
Well when I went in we talked about you and your car. I told him I wanted the same setup.
Old Apr 23, 2006 | 11:37 PM
bigbri's Avatar
bigbri
That was back when I had the Na cams that flowed a lot better than stock...then I changed them ...now I'm changing again...
Old Apr 23, 2006 | 11:39 PM
G352NV's Avatar
G352NV
Well I told him I wanted FI cams. All I know is it doesnt idle for shiet! But hey I guess thats just cams. Hows the car? When are you going to post some fuggin info!
Old Apr 27, 2006 | 11:32 AM
drives4fun's Avatar
drives4fun
ok here are the numbers for scott performance cams
there are 2 cams for forced induction stage one and stage two
stage one cam specs 215.@ .050 dur 403 lift 261degrees @.016 stage two cam specs 213@.050 dur 410 lift 255 degrees @ .018
the magic is in the way the lobe is design for opening and closing the valve.
its not all about lift and duration but when it lifts and when it closes and how fast. you can have the same lift and duration on the cam but the times the valve opens and closes be different, you can loose your power. as we have all heard in this world timing is everything.
Old Apr 27, 2006 | 06:49 PM
alshawi's Avatar
alshawi
JWT, they would be more suitable
Old Apr 27, 2006 | 07:37 PM
Bullitproof's Avatar
Bullitproof
why would a N/A cam in a F/I car be more suitable than a cam designed for forced induction exclusivley?
Old Apr 27, 2006 | 09:33 PM
dscheers's Avatar
dscheers
Anyone want to trade a set of JWT spec cams (less than 1000 miles) and a brandnew set of Tomei 268 for a pair of FI cams like the Scotts ???
Thanks
Danny
pslamp32
Feb 8, 2017 09:07 AM
B Esquire
Sep 24, 2015 07:52 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
