Cams with Vortech?
Old Apr 24, 2006 | 05:27 PM
sccoupe's Avatar
sccoupe
Default Cams with Vortech?
Im currently putting Wiesco 8.8/1 pistons with eagles rods, ARP head and main studs in a brand new short block I just bought with a vortech and 2.87 pulley. The car has a TB, plenum, headers, full exhuast, 440cc, AAM fuel system, 255 fuel pump, technosquare ECU with rev limit upped, JWT flywheel. I would like to make 500hp to the ground on a dynojet dyno and was wondering if I should just leave the stock cams or get the JWT cams or some other cams. Would it be worth the money or am I only going to see 15 or less hp increase? Also if I get the cams should I also do a set of springs?
Old Apr 24, 2006 | 06:33 PM
booger's Avatar
booger
I went with the Nismo cams . They make power thru most of the rpm range . I can feel them kick in around 3000rpm
Old Apr 24, 2006 | 06:38 PM
Julian@MRC's Avatar
Julian@MRC
A 15-20 whp increase on a N/A car would expound itself on a F/I car, so you might make more like 40-60hp, or more depending on the ability to tune for them. If you do go with a set of JWT cams, I do have a set of JWT valve springs and shims in stock..
MRC MOTORSPORTS LLC.
YOUR VQ35 SPECIALISTS
WWW.RACEMRC.COM
732-251-8200
Sales@racemrc.com
AIM: SALESMRC
Authorized dealers for: APS, Greddy, Turbo XS, GT-Spec, Strup, Unlimited Tuning and more.
On site Dyno tuning with our load based Dyno Dynamics Dyno, specializing in Uni-chip, UTEC, Emanage and LS1 Edit.
Old Apr 25, 2006 | 06:43 PM
sccoupe's Avatar
sccoupe
Does anyone have the complete cam specs for the Nismo or JWT cams?
Old Apr 25, 2006 | 06:52 PM
sentry65's Avatar
sentry65
the burninator
my understanding is the JWT cams are similar to the nismo cams except they make slightly less power below 2000 rpms and more power up high
if you have a really light flywheel, you'll rarely drive below 2000 anyway when you're actually going
Old Apr 25, 2006 | 09:10 PM
sccoupe's Avatar
sccoupe
Which Nismo cams?
Old Apr 25, 2006 | 09:28 PM
sentry65's Avatar
sentry65
the burninator
their mild ones
Old Apr 26, 2006 | 03:12 AM
Barzten1's Avatar
Barzten1
Subscribing
Old Apr 26, 2006 | 06:13 AM
Julian@MRC's Avatar
Julian@MRC
I have a set of JWT shims and springs in stock if anyone needs em..$199 shipped!!
Old Apr 27, 2006 | 07:01 PM
alshawi's Avatar
alshawi
The minimum increase of the hp would be about 17-20, ive seen dyno results with JWT cams that increased their hp to 27. Cams are really worth it
Old Apr 27, 2006 | 07:10 PM
Julian@MRC's Avatar
Julian@MRC
Have you seen anyone catually "TUNE" for the cams yet? That is the real million dollar question..
YOUR VQ35 SPECIALISTS AND #1 UTEC RETAILER AND TUNER IN THE COUNTRY!
WWW.RACEMRC.COM
732-251-8200
Sales@racemrc.com
AIM: SALESMRC
Authorized dealers for: APS, Greddy, Turbo XS, GT-Spec, Strup, Unlimited Tuning, HeadGames and more.
ASK about our easy and felxible financing options now available for all your automotive and performance needs!
Old Apr 27, 2006 | 07:31 PM
plumpzz's Avatar
plumpzz
^What do you mean julian? Cant you tune for cams the way you would tune normally?? How would it change teh character of a tune? (For cams lets say)
Old Apr 28, 2006 | 04:30 AM
mojo powered's Avatar
mojo powered
he's talking about a tuned hp difference on an NA car versus stock, instead of just putting the cams in and re-dynoing.
Old Apr 28, 2006 | 05:50 AM
Julian@MRC's Avatar
Julian@MRC
correct..
Old Apr 28, 2006 | 10:40 AM
Bumble350z's Avatar
Bumble350z
do you have to upgrade the ecu to get nismo cams and how long does the installation take?
Old Apr 28, 2006 | 12:59 PM
zachcrosen's Avatar
zachcrosen
Subscribing. I have thought about cams, but havent had the cash to drop on them...Yet!
Old Apr 28, 2006 | 01:00 PM
zachcrosen's Avatar
zachcrosen
Subscribing. I have thought about cams, but havent had the cash to drop on them...Yet! Anyone thought about running the aggressive Tomei cams with the Vortech or any other form of F/I?
Old Apr 28, 2006 | 01:25 PM
Julian@MRC's Avatar
Julian@MRC
To do cams "PROPERLY" and when I say properly, I mean taking having the lash between the valve and cam set properly, install the cams,then tune for the optimal power gain, you would be close to buying a single turbo kit or supercharger.This is why most dont try it..
Old Apr 28, 2006 | 01:54 PM
sentry65's Avatar
sentry65
the burninator
you mean everyone with cams has had them installed the wrong way or something?
install is usually like 8 hours isn't it?
Old Apr 28, 2006 | 02:56 PM
beastie's Avatar
beastie
I don't understand this at all? I just had mine installed with new springs and the works for $650.
