Cams with Vortech?
Old Apr 28, 2006 | 03:03 PM
zachcrosen's Avatar
zachcrosen
Originally Posted by beastie
I don't understand this at all? I just had mine installed with new springs and the works for $650.
You ONLY paid $650 for a cam install? I was quoted at a minimum of $1000 for this near me.
Old Apr 28, 2006 | 03:05 PM
ZRD350Z's Avatar
ZRD350Z
Originally Posted by zachcrosen
Subscribing. I have thought about cams, but havent had the cash to drop on them...Yet! Anyone thought about running the aggressive Tomei cams with the Vortech or any other form of F/I?
I have the Tomei 268's on my car and we will be tuning very soon. I'll keep you guys updated.
Old Apr 28, 2006 | 06:30 PM
Julian@MRC's Avatar
Julian@MRC
Originally Posted by sentry65
you mean everyone with cams has had them installed the wrong way or something?
install is usually like 8 hours isn't it?
No, did not say that, but there are shim kits that need to be used with certain cams. And sometimes the vavle height is slightly off spec and need to have a new bucket with the proper shim installed.This is most often the case when you do a full head job with new valves. But in the JWT cams, they plop right in with the new springs and shims with little adjustments. Some of the more agressive ones may need more adjustments..
8 hours is in the ballpark if your doing cams like the JWT or nimo, cant say how the Tomei or impul fit..
Old Apr 28, 2006 | 06:40 PM
Bullitproof's Avatar
Bullitproof
Scotts cams don't need shims, are perfect for forced induction and comes in a couple different specs. why would you put a n/a cam in a forced induction car if you had the choice? just my two cents.
Old Apr 28, 2006 | 07:01 PM
sentry65's Avatar
sentry65
the burninator
does anyone have the tomei cams in a FI car yet? It all seems theoretical that they'd do well. I'm thinking their duration etc are set up more for NA and might not be the best choice for FI, but I'm just guessing.
Old Apr 29, 2006 | 01:02 PM
Bumble350z's Avatar
Bumble350z
ya the guy at nissan that sponsered me said that i got to do all this stuff and we went over all the est. and i was goin to spend like 3500 bucks on the damn cam set up ...now i am leaning towards the vortech supercharger....my ignorance lead me to think that a supercharger would kill the life of your engine more than turbos...then i asked the guy at nissan and he said that superchargers are more reliable and they are easier to install....have any of you guyz considered f/I?
Old Apr 29, 2006 | 01:07 PM
Bumble350z's Avatar
Bumble350z
Originally Posted by MRC Motorsports
A 15-20 whp increase on a N/A car would expound itself on a F/I car, so you might make more like 40-60hp, or more depending on the ability to tune for them. If you do go with a set of JWT cams, I do have a set of JWT valve springs and shims in stock..
MRC MOTORSPORTS LLC.
YOUR VQ35 SPECIALISTS
WWW.RACEMRC.COM
732-251-8200
Sales@racemrc.com
AIM: SALESMRC
Authorized dealers for: APS, Greddy, Turbo XS, GT-Spec, Strup, Unlimited Tuning and more.
On site Dyno tuning with our load based Dyno Dynamics Dyno, specializing in Uni-chip, UTEC, Emanage and LS1 Edit.
hey how much did the setup for the nismo cams cost you? what other upgrades did you have to do???
Old Apr 29, 2006 | 06:41 PM
Machupo's Avatar
Machupo
i've got the tomei 268's with a built motor right now, have to wait until after my next business trip to pick up the turbos... running pretty much stock tuned and my LSD is giving me a real headache... if i can get those sorted out, i'll be sure to let you know
Old Apr 29, 2006 | 07:42 PM
dscheers's Avatar
dscheers
Subscribing. Have a set of JWT spec cams and a set of Tomei 268s. Need to decide which one to put in my build motor w/ Procharger @ 14psi...
Danny
Old Apr 30, 2006 | 12:20 AM
wilric44's Avatar
wilric44
Default Nismo Cams
I am installing Stillen Stage 2 and was wondering would adding the Nismo Cams help increase the torque. I am trying to get to at least 325 or 335 at the wheels. I see some are barely making this with the stage 4. Are the numbers Stillen posting accurate?
Old Apr 30, 2006 | 03:40 AM
Julian@MRC's Avatar
Julian@MRC
We used JWT cams, slightly different lift and duration than Nismo. We had the lash on the valves set and had to get a whole new set of buckets to be within spec.But keep in mind we also did an entire new Ferrea valve train. I would say with the cams and valves and headwork, expect to pay $5000 or so.But keep in mind this is a full port and polished set of heads,lower intake runner,new valves,new springs,new buckets,cam lash set,cams...
Just to do the cams in an otherwise stock set up , expect to pay about $1100-1300 for cams,$200-300 for springs and shims...And about 10-15 hours labor..
Old Apr 30, 2006 | 03:42 AM
Julian@MRC's Avatar
Julian@MRC
Nissan does not offer sponsorships.....The dealer may have said that to you and took 20% off their already azz-raping bill, to make you feel good, but rest assured its no sponsorship..lol
Old Apr 30, 2006 | 03:44 AM
Julian@MRC's Avatar
Julian@MRC
Danny
I would go with Duration over lift on a F/I car, since your already cramming the air and fuel into the motor to start with. So, whichever has the longer duration..Oh and make sure you do the springs also,they tend to crack under the stresses of F/I and cams..
Old Apr 30, 2006 | 03:57 PM
chris'smax's Avatar
chris'smax
would it be a problem if you keep the stock rev limit?
Old Apr 30, 2006 | 08:21 PM
dscheers's Avatar
dscheers
You really should ask Dr.G this j/k inside joke...
Old Apr 30, 2006 | 08:25 PM
dscheers's Avatar
dscheers
Ok Tomeis have 268 duration and 0.4mm of lift less than the JWTs. So those would be it. Don't I need to worry about overlap ?
Is it important (like decision changing) I'm going with 1 mm oversized valves?
Yes, I'm getting new springs (2 part springs) and the works.
Thanks
Danny
Old May 1, 2006 | 04:38 AM
Julian@MRC's Avatar
Julian@MRC
Thanks
Danny
you do need to worry about the overlap..To much on f/i is not good.. It is tough finding the right amount of lift,duration and overlap..If it were that easy there would be tons of cams on the market for the car.
350Z_Al
Oct 29, 2020 07:44 PM
B Esquire
Sep 24, 2015 07:52 AM
Calinismo350z
Sep 14, 2015 04:04 PM
