Help with HKS DLI!!!!!!!!!!
Old May 9, 2006 | 10:08 PM
bverschage's Avatar
bverschage
Default Help with HKS DLI!!!!!!!!!!
I have tried two different HKS DLI's and the car will not start, but as soon as I take it off the car starts. The car will crank but not turn over, the light to the unit shows power. We have checked all the coil-packs, grounds, and fuses.
I am running the e-manage ultimate, could this have anything to do with it?
Please help!!!!!!!!
Old May 9, 2006 | 10:35 PM
mistaboosta's Avatar
mistaboosta
plug off the e-manage and retry?
btw is it DLI-I or DLI-II ?
DLI-I has known problems with certain cars like EVO etc.
Old May 9, 2006 | 10:40 PM
bverschage's Avatar
bverschage
I have the DLI-II
Old May 10, 2006 | 11:56 AM
bverschage's Avatar
bverschage
any other thoughts?
Old May 10, 2006 | 12:00 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by bverschage
any other thoughts?
Is it properly grounded? Just a thought...
Old May 10, 2006 | 12:04 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Thats weird I have a UTEC and it works fine. If your getting the light to come on the ground is likely good. Are you making sure the wires arent mixed up tp where they need to be? Are you sure you've fully clippped in all the ends? Where did you mount your DLI-II box and what way did you run the wiring loom-behind th eplenum or across the front with the stock harness?
Old May 10, 2006 | 12:37 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by William@Altered
I wonder if it's connected correctly -
You cant really *** up the install unless like I said he screwed up the connectors, meaning he didnt put the short loom to front 2 cylinders, its self explanitory.
Old May 10, 2006 | 01:34 PM
Velicos's Avatar
Velicos
Didn't one member say they had to isolate the unit from the chassis to get the VQ to start up? Put plastic / rubber washers between the unit to make it stand off from your mounting location....
Something to try..
Old May 10, 2006 | 02:16 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I mounted mine touching the frame, no issues started right up...
Old May 10, 2006 | 02:18 PM
mistaboosta
take out a plug and crank the engine to see if you got spark, maybe your dli unit is the failure
Old May 10, 2006 | 02:19 PM
Alberto's Avatar
Alberto
Cranky FI Owner
^^ Hes tried 2 already...
Old May 10, 2006 | 03:35 PM
kim's Avatar
kim
I have the DLI-II with APS TT
No problem at all ///
Old May 10, 2006 | 04:13 PM
Velicos's Avatar
Velicos
Something to try..
https://my350z.com/forum/showthread....hlight=HKS+DLI
Post #16
Originally Posted by Alius_G
Just installed mine today. It's alot easier to disconnect the plugs while their warm. In addition, initially I had the DLI chassis touching the car chassis and it didn't start the car. Once, I isolated it worked fine. Haven't really tested it since it's midnight already..
Old May 10, 2006 | 04:19 PM
sentry65's Avatar
sentry65
the burninator
have you tried disconnecting the emanage ultimate and starting it with the HKS? I'm not sure what injectors you're using or if the car would even start normally without the EU anyway, but just an idea
guess i'm wondering if the EU works fine without the HKS and the HKS works fine without the EU, but them together don't
Old May 10, 2006 | 05:24 PM
bverschage's Avatar
bverschage
hey we are going to give you a call to ensure that it's installed right - we will walk you through it -
I got your message, and I will call you tomorrow. I have tried every thing that I can think of. We grounded the unit to 3 different spots including the battery itself, and have checked and rechecked all the connection. I have run the wires in front of the plenum and behind the plenum; we have mounted the unit as it shows in the instructions, and tried setting it on a few different surfaces.
I think it might have something to do with the original ECU, or the E-Manage. The original ECU still has the turbonetis reflash, and I think that with the E-Manage the signal to fire the car is too weak.
The whole reason that I am putting the unit on the car is that it will not make power over 5000 RPM. When I get to 5000 RPMs under heavy load the car starts to stutter, and you can smell gas, the car will also do this when I down shift on the highway. I think that at 5000 RPMs I am just blowing out the spark on the plugs, so this is why I am trying to use this unit.
The setup that I have is
ECU with the turbonetics reflash
E-Manage Ultimate
Blitz SBC boost controller
750cc injectors
AAM fuel return system
Built motor
8.5.1 pistons
JIC full 3 inch single exhaust
I am running 15 pounds of boost, and on the dyno the boost holds through the rpms, and I have an A/F of 11.2.
Sorry for the long post, just thought that I would give a little more info.
Old May 10, 2006 | 06:40 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Good luck with everything, I also have a TN flash and this unit with no issues. Keep us updated on your situation-btw nice mods list man sounds like a beast....
Old May 10, 2006 | 07:06 PM
bverschage's Avatar
bverschage
thanks, but that is only half the list.
I will let you know what I found out.
Old May 19, 2006 | 03:36 PM
sentry65's Avatar
sentry65
the burninator
did it ever get working?
Mine isn't working either - same exact thing
it appears the emanage ultimate and HKS unit don't like each other
