greddy TT master cylinder check valve?
Old May 11, 2006 | 05:31 PM
baileyrx's Avatar
baileyrx
Default greddy TT master cylinder check valve?
where can I get one? My used lit hade everything except this 1 piece?
Old May 11, 2006 | 06:28 PM
baileyrx's Avatar
baileyrx
nevermind, i just found it.
it's actually an OEM nissan part. (check-valve)
part# 47478-51e00
Old May 11, 2006 | 10:09 PM
AmyCroft's Avatar
AmyCroft
Smile Good to Know Part Number - Hey XBS
part# 47478-51e00
That part was short in my Friend's (XBS) purchase of a used Greedy TT - Very helpful..
Thanks
Cheers Amy -
Old May 12, 2006 | 04:46 AM
supra crazy's Avatar
supra crazy
so what do yo need the checl valve for anyways?
Old May 12, 2006 | 06:03 AM
baileyrx's Avatar
baileyrx
so you don't boost the master cylinder & therefore the brake lines
Old May 12, 2006 | 07:09 AM
theking's Avatar
theking
Breaks only work with vacuum not boost. The check valve makes sure the master cylinder only sees vacuum. Check valves are sometimes called one-way valves.
Old May 12, 2006 | 08:31 AM
overZealous1's Avatar
overZealous1
yes i ran for awhile without it. getting into boost and needing to hit the brakes right after can leave you in a puckering experience when you try and break your seatback by pushing on the brakes so hard, to no avail.
sherm
Apr 11, 2020 05:21 PM
sales@czp
Sep 23, 2019 03:30 PM
