Got My Numbers.....=)
Philthy:That is awesome man. More people/businesses should take after you man.
BigBri: How is she handling on the street? I assume you are using multiple maps via a boost controller. What PSI are you using for just cruising around? I am finally finishing my 5 month build and expect to be in your neck of the woods (power wise) in a month or so. My biggest concerns are running too much HP on the street day-to-day making the car hard to handle and the second is head lift when boosting past 20 psi..
Any thoughts/areas I should watch out for?
--B
--B
--B
--B
Originally Posted by bigbri
No boost controller man ...I've heard to many horror storries about those...For crusing around I'm always at 20lbs in cooler weather my boost goes up to 23lbs...it's really driveable just don't floor it unless your in 4th gear...
About the headlift issue..make sure your head studs at tqed down really good and don't run aggressive timing and I think you'll be fine...
I can't wait to get my car back together... I was racing last Friday and blew my axle at MIR... Apparently my Level 5 Axles are pretty much bulletproof, but my inner CV was not..
SO, we have the back end apart and are replacing the left axle, the inner CV joint and dropped the ATS diff in... OH, for your FYI, that diff dropped in perfectly, did not even have to shim it.. --B
Bri,
Sick man. I thought Marin would be the 1st to hit those kinda numbers. I remember riding in your little beast back at 13 water-injected psi. What the *** are you thinking pushing 23? lol..
gimme a ride,
romy (assmnky)
gimme a ride,
romy (assmnky)
Originally Posted by slay2k
Bri,
gimme a ride,
romy (assmnky)
gimme a ride,
romy (assmnky)
Originally Posted by taurran
How do you all manage to put all this money into your cars but not have a nice video camera to get good video? When can we expect more than a short, shaky 3rd gear run video?
I agree...I'll have something by this weekend....
Cool! I'm looking forward to it. If you need webspace to host a large file, I can host it one of my personal webhosts. That is, unless you really like the special ed flamefests on streetfire.
