L19 Extreme Duty Head Studs have arrived!
Old May 16, 2006 | 06:54 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
The cost of L19 studs compared to 1/2" studs including the machining, down time, etc is roughly half as much.
For comparison, 1/2" studs for a Supra including parts, labor, etc is $750. Should not be much different for the VQ. Don't forget the down time on waiting for your machine shop to get back to you.
Old May 16, 2006 | 07:46 AM
Gman2004's Avatar
Gman2004
what should one expect to pay for parts and labor to get these installed?
Old May 16, 2006 | 07:55 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Assuming that your engine is already installed in the car, labor would be roughly $1500-$1600. It's basically the cost of a cam install, plus another hour to install and setup the studs correctly.
If you have a new shortblock that you are planning to install, there woud be no extra labor involved, since these studs would simply drop in without any mods.
Old May 16, 2006 | 08:00 AM
Gman2004's Avatar
Gman2004
Thanks Sharif. I'll sit back and watch for a while and see how these things do on other people motors before taking the plunge. I would hate to spend $2,100 and still have problems. How many orders have you got so far? Any idea on when those orders will be installed and running?
Old May 16, 2006 | 08:19 AM
Sharif@Forged
Forged Performance
About 10 sets of shipped to various people, so I imagine it will be a few weeks before they are installed and running. The process is very straightforward, so I know they will work!
Old May 20, 2006 | 07:20 AM
fito's Avatar
fito
has anyone test them yet?
Old May 22, 2006 | 07:02 AM
Sharif@Forged
Forged Performance
Very soon, I imagine. There is nothing really to test, other to insure that 90-95 ft/lbs is sufficient clamping force. For their stated purpose (maximizing clamping force on on unsleeved, unmodified block), there should work just fine.
I would still consider doing 12mm or 1/2 inch studs on sleeved blocks.
Old May 27, 2006 | 04:45 PM
Sharif@Forged
Forged Performance
We've got about 6 sets left from the first batch of 20 sets.
Old May 27, 2006 | 05:38 PM
Gman2004's Avatar
Gman2004
Should work just fine? What are the chances that these studs don't hold the heads down as well as the regular ARP studs?
Old May 27, 2006 | 06:46 PM
Sharif@Forged
Forged Performance
No chance whatsoever. They are 40% stronger.
Old Jun 1, 2006 | 07:24 AM
Gman2004's Avatar
Gman2004
What about the thread pitch? Aren't they same as stock. Wouldn't having the same OEM thread pitch while campling them down so much cause they to eventually strip out?
Old Jun 1, 2006 | 07:35 AM
Sharif@Forged
Forged Performance
We tested the standard ARP stud to 110ft/lbs before the threads broke. So torqueing them down to 90ft/lbs is well within an acceptable range of L19, with factory threads in the block.
The sleeved block 700whp+ crowd would probably still consider 12mm studd upgrades. For the majority of people in the 500-700whp range, these will be suitable.
Old Jun 1, 2006 | 07:40 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
ill have them on and tested in about a month.
Old Jun 1, 2006 | 10:44 AM
failsafe306's Avatar
failsafe306
I may beat you to it
Old Jun 1, 2006 | 02:19 PM
booger's Avatar
booger
Doing mine in a week and a half also . Taking a vacation first
Old Jun 1, 2006 | 02:33 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
or 1/2" (12.7mm)
studddddddddddd
Old Jun 2, 2006 | 02:55 PM
Sharif@Forged
Forged Performance
Originally Posted by 350zDCalb
or 1/2" (12.7mm)
studddddddddddd
One interesting point, is that the 12mm studs do not require you to drill your heads, or your gasket.
Old Jun 2, 2006 | 03:37 PM
  #38
meatbag's Avatar
meatbag
So only the block has to be drilled and taped? Thats interesting.
Old Jun 2, 2006 | 04:21 PM
  #39
350zDCalb's Avatar
350zDCalb
builtZmotors
ummmmmm, the stock size holes in the head are 11.80-11.9mm
the stud requires approx. 40 thousandths clearance to get the head on with ease...so, approx 1mm additonal clearance in diameter... the clearance in the head should be: 12.8mm+
if the 12mm stud is smaller than 12mm, then I assume it would be an extremely tight fit, probably requiring installing the studs through the head, after it is placed on the block/ vs fitting the head over the studs...
-T to the O to the double D
Old Jun 2, 2006 | 07:01 PM
  #40
Sharif@Forged
Forged Performance
It fits...I just shipped off a set 12mm studs to someone, or else I would whip them out and measure them myself.
You know the person to ask...for confirmation.
