vortech installed...how can i gain more hp?
Old May 22, 2006 | 02:13 PM
xav_350z's Avatar
xav_350z
Default vortech installed...how can i gain more hp?
guys i just installed my vortech Sc , what other modifications are needed to gain more HP???
got the HKS dual exhaust , jwt fllywheel , nismo clutch , B&M short shifter, and tannabe springs...
any suggestions?
10x
Old May 22, 2006 | 02:16 PM
Oleg's Avatar
Oleg
any suggestions?
10x
Switch to a twin turbo.
Just kidding.
Smaller pulley, fuel system upgrades, better engine management. There are a few guys on the forums that made high power on built motors.
If you want something low budget and about 400whp, contact a member named LiNkS and ask him.
Old May 22, 2006 | 02:27 PM
xav_350z's Avatar
xav_350z
i was confused between the aps single turbo kit and vortech.
but i ordered the Sc P
i'll contact links ! 10x man
plumpzz's Avatar
plumpzz
I'd first install a quality set of headers like strup, DC, nismo, crawford. If you still want more power, new pully and UtEC, if you still want more, JWT cams, and then if u want more, built engine w/ Ttrim blower +bigger IC + bigger injectors
Old May 22, 2006 | 02:33 PM
xav_350z's Avatar
xav_350z
should i replace stock pistons?
Old May 22, 2006 | 02:39 PM
plumpzz's Avatar
plumpzz
won't do much. if you want real power like 500+ i say you contact someone on the boards by the name "Booger". I believe he has a built motor, T trim blower as wellas a bigger i/c. hes up there in the HP range.
You can also swap to a 3.9 FD which will give you a 10% boost in acceleration (not power)
Old May 22, 2006 | 02:41 PM
booger's Avatar
booger
Headers and breathing mods are the first thing I would do . Then you can go to a smaller pulley [ 3.12 ] will add around 25whp . The [2.78] pulley will get you another 25whp . Some claim much more than that . The 3.12 pulley can be run safely on the stock kit . But when you go to the 2.87 , it can be run on the fuel system , but I would think about going with a upgraded fuel system . And lastly , you can go to a different EMU for more control of the timing and fuel to gain a few more WHP
Old May 22, 2006 | 05:44 PM
backagain's Avatar
backagain
im running 400 wheep hp at just under 8 psi. Mods are vortech with 3.12 pulley, dc sport headers, test pipes and borla td exhaust, tuned by cpracing. i guess i had some belt slipping when the new pulley was put on or something but now im hitting between 9 and 9.5 psi. I havent re-dynoed but hoping to very soon. one day i'll jump down to the 2.87 and also a nice return fuel system. I would honestly like to get just under 500 hp but i know i'll need a few more mods. Plenum being one of those, cam's wouldnt hurt as well.
Old May 23, 2006 | 01:26 AM
alshawi's Avatar
alshawi
XAV, all u need are headers, test pipes, and a plenum spacer or the intake plenum itself, then if u want more gains, go for JWT cams. This is what i have done. I hit around 400 whp with stock boost
Old May 23, 2006 | 04:30 AM
blackend's Avatar
blackend
alshawi,mabrook that you hit 400whp,any dyno picture you have and did you upgrade your VB,TC?
Old May 23, 2006 | 05:03 AM
alshawi's Avatar
alshawi
thanks blackend, its actually just a bit more than 400, and i have ordered a new tranny from the dealer so i can send it and the ecu to forged internals, it should be in bahrain by 2 weeks.
Old May 23, 2006 | 06:38 AM
blackend's Avatar
blackend
did you dyno the car?what max psi you reach with over 400whp?cause same your mod we done alot of them but never hit over 400whp,did you use the tuner kit?it is amazing that you hit as you say more than 400whp,what is your tq?
did you order new VB?or the hole tranny and how much it cost you,,,at least post your dyno
Old May 23, 2006 | 04:22 PM
xav_350z's Avatar
xav_350z
i guess i m gonna order headers , cams , brake rotors soon.
u guys recommend any dealers out there?
i ordered the parts from mynismo.com , but they still have their site down...
and 10x for the advices !
Old May 23, 2006 | 04:52 PM
thawk408's Avatar
thawk408
If you want some good headers I would look at the Crawfords. He just came down on the price too.
Old May 23, 2006 | 04:54 PM
doug's Avatar
doug
post 666 at that
Old May 24, 2006 | 06:11 AM
xav_350z's Avatar
xav_350z
i have the HKS Dual Hi-Power Ti Exhaust on my z , which headers will best fit????
Old May 25, 2006 | 11:43 AM
BeerViper's Avatar
BeerViper
I know there's been debates here on headers before but I can't remember who with ... from what I understand (not speaking from experience) is that headers will only gain you 2 - 3% gain hp for a very high cost. Just my $.02
Old May 26, 2006 | 05:52 AM
dimebagdolf's Avatar
dimebagdolf
Headers will only get you a little (if anything) on an NA car, but once you go Supercharged... "you're gonna want those headers"
- Bruce Dickinson
I would definilty recommend going with JWT cams. I they'll get you a pretty substantial gain w/out having to run more boost. That was the route I took. Praying for a stock motor that will last me a long time, be problem free, and smog legal.
Old May 26, 2006 | 07:21 AM
sentry65's Avatar
sentry65
the burninator
i agree with dimebagdolf, people with sc's make a lot of power with cams and headers
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
