VQ35 Solid Motor Mounts
Old Jun 1, 2006 | 02:59 PM
overZealous1's Avatar
overZealous1
Originally Posted by Sharif@Forged
That is some amazing tig welding..nice work, IP.
I'll be using these mounts on my engine, once the move to Marietta is complete.
actually, the weld is contaminated with slag and zinc. the black and the hole on the side show that, that weld would never pass certification. the bolt and water jetted (or stamped end) end need to have the slag ground off and start with a clean surface. then the welds would be perfect, lol. ok, i but out now
Old Jun 1, 2006 | 05:28 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Damn..everyone is critic. You are a true nerd..hehe.
Old Jun 2, 2006 | 06:04 AM
tig488's Avatar
tig488
Originally Posted by leeboyNY
Alright, solid motor mounts might be the solution to a minor problem I'm experiencing... APS ST crossover pipe is hitting the firewall during the hard acceleration... If motor can be dropped lower there will be more clearance between the crossover pipe and the firewall, and if the motor doesn't move, pipe won't hit.... That will totally solve my problem!! About the increased vibration.. How bad will it be?
or you could do what i did, take a mallet to the firewall and beat it in a few mms.
Old Jun 2, 2006 | 06:26 AM
sq40's Avatar
sq40
This thread is more vicious than a San Fransisco **** fight...
Old Jun 2, 2006 | 08:15 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Sh*T Tig!! I didn't know you did that... Did your's also hit and make vibration noises?
Old Jun 2, 2006 | 12:39 PM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
The black is the coating from the Grade 8 bolt due to heat put between the two metals, as well as the pit on the left side is lifting off of the gas from the TIG welder. What certification are you talking about that it would not pass?
actually, the weld is contaminated with slag and zinc. . the bolt and water jetted (or stamped end) end need to have the slag ground off and start with a clean surface. then the welds would be perfect, lol. ok, i but out now
Slag ground off from what?
I would love to see the welds of the motor mounts you have built as well as other products you have made.
TIA.
Old Jun 2, 2006 | 12:48 PM
XBS's Avatar
XBS
Veteran
This is great, too bad you cant put any patents on your ideas scott. oh well thats life i guess. Ill stick with my $110 SVR and keep the 185 for the ladies at the strip club
Good luck to both of you!
Old Jun 2, 2006 | 12:53 PM
InjectedPerf
Like I said before, I am not saying anything bad or degrading of SVR's product. I have never seen it. Just would like clarification on the points he has made on our mounts.
Quick questions: If the nut on the top of the bolt comes loose, and the bolt falls out of the bottom of the mount, what is holding the motor in place?
Old Jun 2, 2006 | 01:03 PM
sentry65's Avatar
sentry65
the burninator
does the nut go on the top or bottom on the SVR's?
I didn't install mine so I don't actually know
I'm not worried though
Old Jun 2, 2006 | 04:15 PM
tig488's Avatar
tig488
yeah, it wasnt rubbing much, it only took a few hits to move it in a few millimeters.
Old Jun 2, 2006 | 04:33 PM
XBS's Avatar
XBS
Veteran
Well you place the nut on the bottom, so if the nut were to "magically fall out" the bolt would still be there in place to hold the motor and i doubt it will go anywhere or that the nut would fall out.
Old Jun 2, 2006 | 05:36 PM
Daninjectedperf's Avatar
Daninjectedperf
Unfortunatly patents only apply to a copy of a similar product. As you can see our motor mounts are made from superior materials and the fit and finish is better as well. Our motor mounts use a stud configuration on both sides which as we have all learned from using head studs on upgaded motors provides superior clamping force. Also this very same design has already been proven on many high HP Toyota Supras. We run the same designed mounts in our 1200hp Supra for the past 7 years!!! We are simply bringing this design over to the 350z market. I understand that there may be other products out there that are cheaper and as we all know you get what you pay for.
Supra mounts:
Old Jun 2, 2006 | 06:04 PM
failsafe306's Avatar
failsafe306
Could you at least offer a lower introductory price, or offer a group buy or something? I'm looking to install some mounts since my motor is out at this time, and figure this is the perfect time to do so. But I won't pay $295 for motor mounts, sorry
Also, are you keeping these in stock, ready to ship? Or making them to order?
Old Jun 2, 2006 | 07:12 PM
sentry65's Avatar
sentry65
the burninator
I hope these mounts are almost 3 times the quality to cost almost 3 times the cost of the SVR's.
I've never seen motor mounts cost so much - maybe if they were made of solid carbon fiber with titanium reinforcement beams or something like that would $295 be a justified price for them
http://store.summitracing.com/egnsea...105+301035+115
all the solid motor mounts for other cars on summit racing's site are $25-72
Old Jun 2, 2006 | 07:25 PM
Juanito350Z's Avatar
Juanito350Z
Group Buy.. Group Buy.. man there pricey.. but I want them..lol
Old Jun 2, 2006 | 08:05 PM
Daninjectedperf
We do stock these mounts. Currently have four sets in stock. More coming next week.
You are comparing short run sets (VQ) to companies like Moroso that mass produce a part for domestic cars. Summit also sells a set of 8 connecting rods for $250 whereas the most popular rod for the Z (Pauter) sells for well over $1,000 for a set of 6.
Old Jun 2, 2006 | 08:08 PM
Daninjectedperf
I will look into having a group buy and let you know early next week. Thanks for the idea
Old Jun 2, 2006 | 08:52 PM
  #38
Nismo350ZRT's Avatar
Nismo350ZRT
Any chance that IP or SVR can make custom motor mounts that raise the motor? I'm installing the APS TT on my 06 and I need to raise the LHS of the motor for clearance. I plan on using washers but custom mounts would be so much nicer.
Old Jun 2, 2006 | 08:54 PM
  #39
Daninjectedperf
Absolutley! Give us the specs and we can have you a set made right away for the same price.
Old Jun 3, 2006 | 06:03 PM
  #40
sentry65's Avatar
sentry65
the burninator
hey just curious, would solid motor mounts possibly have any effect on the balance of the engine? If you don't have the engine moving all over the place, would the crankshaft and internals not have as much forces excerted on them? - like if you had a tin can full of rocks and you shake the can vs not shaking it
