Question on UTEC
Will the UTEC allow you to raise the idle and the Rev limiter?
I would rather not send in my ECU anywhere to get flashed.
What is the link to a good UTEC site.
Thanks...
Thanks...
Art, With the Utec you can alter your rev limiter, but you can Not change your idle through it. You can scale injectors with it tho. Link http://www.turboxs.com/UTEC.htm
Kevin
Kevin
Ok so,
You can raise the Rev w/ the UTEC and the Idle with the CIPHER?
http://www.alteredatmosphere.com/mm5..._Code=STRFRONT
That should be almost all ya need then, right...
