UTEC OPEN LOOP Problem
Old Jun 19, 2006 | 05:33 AM
  #41
Julian@MRC's Avatar
Julian@MRC
Originally Posted by 35ounces
Hey Julian can you please post the temp correction spreadsheet (or send it to me)? Thanks.
When I get to the shop I will do that..
Old Jun 19, 2006 | 05:37 AM
  #42
aalzuhair's Avatar
aalzuhair
Originally Posted by MRC Motorsports
So how does the UTEC know where it is in the 0% load colum? By magic?
The UTEC still uses MAF based fueling until it goes into the 10-100% load columns.
It would know where it is in the 0% column by the RPM point. If you have a range of RPM and only one column, you will ONLY have one point for every RPM point... thus, why would you need the TPS?!?!?
Fuel tuning in the 0% column is done “piggyback style” using injector scaling and MAF voltage offset. Tuning of the 0% column is done mainly by using
the Injector Flow parameter value settings in the Open Loop Fuelling parameters menu. Based of the aforementioned, any changes applied on the 0% column and at a certain RPM point would apply across the board on the same RPM point on the stock ECU fuel map regardless of the MAF point of the stock ECU.
Old Jun 19, 2006 | 06:01 AM
  #43
Julian@MRC's Avatar
Julian@MRC
And what do you think tells the MAF and the Trottle body how much to open and what background map to run on the stock ECU, which controls the car in the 0% load column. Im telling you the UTEC needs some input of the TPS regardless open loop or closed loop..If you wish to debate with me based on your vast tuning experience then do so via PM and stop hijacking this thread with debate.
Old Jun 19, 2006 | 07:03 AM
  #44
aalzuhair's Avatar
aalzuhair
Don’t take it personal man I’m not doubting your tuning abilities. And I’m not here to hijack this thread It would be nice of you to teach us a thing or two about tuning and how does the TPS controls the MAF sensor; it might be beneficial to all, but if you wish otherwise, so be it.
Az
Old Jun 19, 2006 | 10:47 AM
  #45
mistaboosta's Avatar
mistaboosta
i made the changes to the TPS Min Voltage and TPS threshold for Mapping as you said. Set the injector scaling to 380 / 380 and modified the %0 column not to bog the car but this didn't help. The car bogged and died. I wasn't able to run it again for half an hour (prolly the plugs were wet with fuel).
BTW thanks for all the inputs guys!
Julian,
I've sent u a pm on another issue.
Old Jun 19, 2006 | 10:54 AM
  #46
35ounces's Avatar
35ounces
03 CS Track 6MT
did you use a bunch of negative whole values in the 0% column? Lets see what you have.
Old Jun 19, 2006 | 01:05 PM
  #47
mistaboosta
i didn't bring the laptop home but the %0 column is full of negative values which starts from -8 and decreases.
Old Jun 20, 2006 | 02:59 PM
  #48
mistaboosta
it would be great to hear how to calibrate those numbers into UTEC. also it's weird that this info is not included in the manual!!
Old Jun 20, 2006 | 04:02 PM
  #49
35ounces's Avatar
35ounces
03 CS Track 6MT
The MAP numbers or the 0% column?
There are instructions for the map sensor in the manual IIRC and the 0% column is explained...you have to road or dyno tune the column to your target a/f. It works a slightly different from the other columns because it is piggyback style values whereas the others are injector time values.
Old Jun 20, 2006 | 05:47 PM
  #50
Audible Mayhem's Avatar
Audible Mayhem
My350z
well i am putting a fully built TT motor in my car this weekend and switching it from the EU that runs it now in the G to my UTEC. i hope i dont have any problems, but if i do, i know where to look!!
Old Jun 20, 2006 | 09:43 PM
  #51
mistaboosta
No i'm talkin about how to calibrate MAP sensor using the "values" that are given on the calibration paper of the MAP sensor.
Old Jun 20, 2006 | 09:44 PM
  #52
mistaboosta
people are having a few problems with UTEC but still I think that it is a strong EM.
Old Jun 20, 2006 | 09:51 PM
  #53
aalzuhair's Avatar
aalzuhair
You would need the attached excel sheet, where you input the numbers in and it will give you the numbers that you can use with the UTEC.
Az
File Type: zip
Old Jun 21, 2006 | 01:21 AM
  #54
mistaboosta
It calculates 112 / 169 I'll see if these numbers will work.
Thanks a lot man.
Old Jun 25, 2006 | 01:22 PM
  #55
mistaboosta
I've entered the numbers as 112 / 169 and the UTEC is reading the MAP wrong! It reads - 12.5 psi @ idle which is actually around 8.5 psi.
Old Jun 25, 2006 | 01:48 PM
  #56
Julian@MRC's Avatar
Julian@MRC
Dude, if your getting 8.5 psi of boost at idle you got bigger issues...
Old Jun 25, 2006 | 01:53 PM
  #57
mistaboosta
LOL
it should be -8.5 psi for sure
Old Jun 25, 2006 | 01:56 PM
  #58
Julian@MRC's Avatar
Julian@MRC
LOL
Actually vacume on my car reads -15 to -20 at idle...
Old Jun 25, 2006 | 01:58 PM
  #59
mistaboosta
psi ?
Old Jun 25, 2006 | 02:05 PM
  #60
35ounces's Avatar
35ounces
03 CS Track 6MT
-15 to -20Hg's of vac at idle is normal for our cars.
