Advice/help Needed!!!!
Old Jun 15, 2006 | 10:57 AM
kamal34's Avatar
kamal34
Exclamation Advice/help Needed!!!!
Hey guys, my cars been MIA for some time now. I have a twin turbo setup and built motor. I am running nitrous intercooler sprayers just to kind of give you some background.
My car was complete and ready to get tuned. Whenever it was taken for a test drive, the car would choke at around 4,000-5,000 RPM. The car is doing this all the time and throws up a "crank angle sensor position error". That is the only code the car is throwing up and weve done everything to try to fix the problem. Weve tried 8 different crank sensors and none of them work. We bought a new ECU and Harness for the car thinking the wires were bad... We've fixed everything and tried everything but now were scratching our heads.... Any input would be great.
ps. The car is making boost at lower rpms and then just chokes at mid to high range... PLEASE HELP ME!!!!
Old Jun 15, 2006 | 08:38 PM
overZealous1's Avatar
overZealous1
what engine management? did you set the boost/airflow limiter setting to clip the maf signal?
sherm
Apr 11, 2020 05:21 PM
