Advice/help Needed!!!!
Old Jun 15, 2006 | 10:58 AM
kamal34's Avatar
kamal34
Exclamation Advice/help Needed!!!!
Hey guys, my cars been MIA for some time now. I have a twin turbo setup and built motor. I am running nitrous intercooler sprayers just to kind of give you some background.
My car was complete and ready to get tuned. Whenever it was taken for a test drive, the car would choke at around 4,000-5,000 RPM. The car is doing this all the time and throws up a "crank angle sensor position error". That is the only code the car is throwing up and weve done everything to try to fix the problem. Weve tried 8 different crank sensors and none of them work. We bought a new ECU and Harness for the car thinking the wires were bad... We've fixed everything and tried everything but now were scratching our heads.... Any input would be great.
ps. The car is making boost at lower rpms and then just chokes at mid to high range... PLEASE HELP ME!!!!
Old Jun 15, 2006 | 11:01 AM
MIAPLAYA's Avatar
MIAPLAYA
Waht flywheel are you running? Could be the flywheel does not have the pickup trigger in the right location.
Old Jun 15, 2006 | 12:22 PM
kamal34's Avatar
kamal34
im still running the stock fly wheel. We checked the flex plate and it was fine. No damage but I dont think we went into it detailed. I will check it out. Thanks for the advice man
Old Jun 15, 2006 | 02:00 PM
bsp's Avatar
bsp
Brainstorm Performance
Posting which turbo kit you have might get you some more help.
Old Jun 15, 2006 | 03:14 PM
kamal34's Avatar
kamal34
I have always had the Speed Force Racing kit. Ive had it since May/June of 04. Its a recent problem. Were taking it to the dealer tomorrow so they can run a complete diagnostics. Ill keep everyone posted.
sherm
Apr 11, 2020 05:21 PM
