HELP!Problem with Procharger.HELP!
Old Jun 23, 2006 | 07:31 AM
sajmon's Avatar
sajmon
Default HELP!Problem with Procharger.HELP!
Hello,
I've put a Procharger to my 350 z and there is a problem that the oil from engine is throwing out to the air filter!
Do You know why it is like that?
Please help.
Old Jun 23, 2006 | 10:28 AM
Vertex350's Avatar
Vertex350
Take it to the dealer.
Old Jun 23, 2006 | 10:52 AM
Swiffer's Avatar
Swiffer
ummm....wow
Do you have a crack in the block or something?? If you have oil coming out of the engine, then you have some SERIOUS problems.
Old Jun 23, 2006 | 10:55 AM
rythex's Avatar
rythex
Uhm, wouldn't the oil possibly be from the charger instead of the engine?
Old Jun 23, 2006 | 10:59 AM
abyss's Avatar
abyss
umm...help you need indeed.
Old Jun 23, 2006 | 11:01 AM
Elohite's Avatar
Elohite
popcharger?
Old Jun 23, 2006 | 11:02 AM
VO...'s Avatar
VO...
Administrator
Dodge Charger?
Old Jun 23, 2006 | 11:14 AM
SpeedRcr's Avatar
SpeedRcr
is the dipstick pushed all the way in?
Old Jun 23, 2006 | 11:55 AM
Mazinger Z's Avatar
Mazinger Z
Oh man, that sounds horrible...are u sure it's cuz of the popcharger?
Old Jun 23, 2006 | 01:13 PM
Mathys's Avatar
Mathys
Are we talkin' about a popcharger or a supercharger?
Old Jun 23, 2006 | 01:40 PM
VO...'s Avatar
VO...
Administrator
Maybe a cell phone charger?
Old Jun 23, 2006 | 03:44 PM
ZedNewbie's Avatar
ZedNewbie
Did this happen right after the install? Or after driving it around for awhile?
Old Aug 8, 2006 | 08:03 AM
jasonM's Avatar
jasonM
had same problem get an oil catch can
Old Aug 8, 2006 | 12:21 PM
chrisle7220's Avatar
chrisle7220
San Diego Charger?
Old Aug 8, 2006 | 12:26 PM
plumpzz's Avatar
plumpzz
Charging bull?
Old Aug 8, 2006 | 01:44 PM
rrmedicx's Avatar
rrmedicx
You may consider an oil catch can, or check to see if you simpoly put too much oil into the supercharger. This I think is pretty hard to do, since the oil for the supercharger comes in such small bottles and it is precisely measured so its hard to over-fill, but anything is possible. The oil must be from Procharger, or your warranty is void.
I think the kit naturally spits out a little oil into the intake system, so I would start with an oil catch can.
Please be a little more detailed about where the oil is coming from.
What set-up do you have, standard pulley or bigger 9lb pulley???
Old Aug 8, 2006 | 04:18 PM
KPierson's Avatar
KPierson
I would recomend a compression test. A small amount of oil is normal, but anything more then a small amount would indicate a cracked ring (or two). Once you crack a ring you are basiclly pressurizing your crank case which will shoot oil back in to your intake (where your filter is).
Good luck!
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
