Orc Z33
Old Jun 27, 2006 | 01:18 PM
350Z-YOU's Avatar
350Z-YOU
Default Orc Z33
Anybody has anything on ORC's twin supercharged 350? I did a search but did not find anything> Thanx.
Old Oct 15, 2006 | 01:39 PM
kaybee650's Avatar
kaybee650
http://www.350z-club.ch/include.php?...&contentid=329
kaybee650's Avatar
kaybee650
ok someone translate please
Old Oct 15, 2006 | 01:41 PM
Zexy's Avatar
Zexy
That's a huge blower.
Old Oct 15, 2006 | 01:46 PM
chimmike's Avatar
chimmike
if you have the google toolbar, right click on the webpage, go to page info, and hit translate.
it may not be pefect though lol
Old Oct 15, 2006 | 01:47 PM
chimmike's Avatar
chimmike
it's not twin supercharged, it's twin-charged. a turbo and a blower.
Old Oct 15, 2006 | 05:49 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
If 550 HP strong sipping on racers into momentum comes, it presses its passengers into the seats and joy tears into their eyes.
Already during the reading of the tuner involved one snaps the tongue: Under the direction guidance of clutch manufacturer ORC considerable Japanese noble put like Top Secret, Bravery, Rays engineering, Project µ, Obayashi Factory and Maziora hand at this Augenschmaus. Widebody kits, extreme Verspoilerung, air chassis and 550 HP of strong V6 with Twincharger technology (compressor and turbo) are only a few bitebite bites, which the wuchtige Nissan has to offer.
Styling
For ORC there was a possible direction with the Design only: as extremely as possible. One oriented oneself thereby at the D1-Drift-350Z von Top Secret. A brutally broad GT 300 Widebody kits pustet the sportsman on show-car-taugliche mass. Particularly the extended front apron and the Seitenkiemen before the doors betray, which forces under the hood schlummern
This had to let just as extensive change work over itself be issued. In order to provide for the highly lying compressor place and breathing air, an enormous air intake on the hood, which reminds of American Muscle Cars, thront. Those breeding hot engine warmth is again exhausted by two smaller air discharge openings. In the back a GT spoiler from easy-weighty carbon presses the Nissan on the road. It is supported by a diffuser likewise developed from carbon, which sucks the 350Z firmly to the bitumen.
After the optical force cure had succeeded, ORC dipped its present Racer into a Maziora-Flip-flop-Farbenpracht with additional Airbrush motives. Depending upon beam of light and angle the Coupé in Perl white, Mintgruen or easy blue gleams. Particularly the issued body areas become effective so well. Every time the Nissan stands, he becomes from being astonished masses encircles. One does not have to turn thus times the ignition key, in order to excite with the broad flounder attention. To the motor muscle play however later more.
Interieur
Joy does not only arise with inspired passanten. Drivers and front seat passengers slip into leather-referred Bride of seats, which keep them also with highest drift inclination in the saddle. At the removable Key's Racing steering wheel one can celebrate the most beautiful Kurbelorgien. In addition, for the front seat passenger each quantity is play and tension on board. The completely transformed instrument panel offers properly matching Unterschlupf for the standard instruments, the enormous Alpine screen including plant as well as lightning load pressure control valve with color display. Under the air conditioning system are the NOS switches, which activate four tanks installed in the trunk.
On the front seat passenger side six lightning announcements are attached. They hold the driver over important temperatures and pressures up to date. Pilot and copilot are from numerous Surround sound loudspeakers distributed in the cockpit encircle beyond that. Together with a largeturned out Subwoofer plentifully basses the adrenalin inflation, if the loaded six cylinder straight inserts times a break.
Engine/chassis
Under the airy hood a really high performance power coalition works. Compressor and turbo werkeln as so-called Twincharger in the double luggage and provide for 550 HP and torque Tsunamis. With low routes the spontaneously responding compressor goes into action and supplies steam in the number of revolutions cellar. If one leaves the needle high-fast, the compressor switches itself off and leaves to the enormous turbocharger the field. In such a manner encouraged the Nissan in each course tears almost linear forward, brachialer thrust is always present. NOS again increases the achievement by 100 HP and the mood by a multiple. So the Nissan could go through also as "Tricharger".
And for the sound supplied in addition ORC could require also admission fee. Compressor-howl, V6-Fauchen, exhaust Brotzeln, turbo-whistles and Wastegate Schnattern result in a unique Symphonie. We could be hinreissen to a few Burnouts, but supply the Bridgestone tires with the help of the Nismo barrier a outstanding traction.
Cusco feathers/springs and the air chassis of Roberuta make each bend a new ideal line or the drift scene, depending upon position of the gas pedal.
Behind the ultrageilen people Racing rims works in front a brake assembly of Project µ. 6-Kolben-Saettel presses the special linings mercilessly hard on the slit disks and retards the 350Z if necessary brutally down. Such impressing performance leaves again and again a Grinsen in the driver face. We can recommend the ORC-350Z even as cures. Laugh is considered as healthy!
Facts
Type: Nissan 350Z, year of construction 2006
Engine: 3,5l 24V with ORC compressor kit, lightning K5-660R turbocharger, lightning Wastegate, ARC intercooler with NOS cooling, ARC wasserkuehler, Bravery SUS air cleaner with titanium syphon, larger butterfly valve, approx.. 550 HP
Wheels: Rays engineering people GT-7 VA: 9,5x20 tariff with 245/35/20 hectar: 10x20 tariff with 285/30/20
Chassis: Cusco feathers/springs adjustably, Roberuta air chassis, Project µBremsbelaege all around, Project µBremsscheiben slit and Project µ 6-Kolben-Bremssaettel in front
Exhaust: particularly made elbow unions and exhaust system of Bravery
Spoiler: complete Top Secret g-Force Widebody kit, particularly made Bravery SPL hood, Top Secret tail wing, Top Secret diffuser
Interieur: Bride Ergo II leather seats, Key's Racing steering wheel with quick-locking mechanism, Obayashi Factory center console, lightning SBC ID load pressure control valve, Neck corporation AF-700 air/gasoline mixture announcement, lightning announcements for load pressure, gasoline pressure, oil pressure, oil temperature, water temperature and exhaust gas temperature, variable trillion exhaust price increase
Extra: ORC drift box, ORC alarm installation, complete Alpine audio/video plant of Obayashi Factory, Maziora Flip-flop-Lack in Perl white, blue and green
sales@czp
Sep 23, 2019 03:30 PM
foxsmp26
Sep 25, 2015 09:48 AM
