Overheating, weird color coolant, coolant all over engine.. pictures
Old Jul 11, 2006 | 04:24 PM
doug's Avatar
doug
Default Overheating, weird color coolant, coolant all over engine.. pictures
so far what i have been reading is that i may have air bubbles in my cooling system.. this is what i am hoping for... I noticed Sunday that i had coolant all over my hood and when i looked under the hood i see coolant had been all over the engine.
I never had an over heating problem until today, i noticed my temp gauge was all the way up to H. I am really hoping its not headlift since i am only running 5.5 PSI on a Greddy Kit..
anyone want to take a look a the pictures and give an idea?
Old Jul 11, 2006 | 04:35 PM
Weqster's Avatar
Weqster
u are blowing boost into ur coolant sleeves. Sorry to say, ur headgasket is toast.
Old Jul 11, 2006 | 05:01 PM
k3silk's Avatar
k3silk
hope he is wrong... by the way is that a rev up motor?
Old Jul 11, 2006 | 05:06 PM
doug's Avatar
doug
nah.. 03 ..
i am hoping and praying its either bubbles in the system or thermostat...
i hardly boost.. so i am hoping that luck is on my side... that and my EGT's have never gone over 1500
Old Jul 11, 2006 | 05:17 PM
VN_350z's Avatar
VN_350z
this is no way done by air bubbles in coolant system. This is busted head gasket...boost pressure got in there
Old Jul 11, 2006 | 05:29 PM
eat rice z33's Avatar
eat rice z33
or you could of boiled over the fluid and it simply overflowed the overflow tank and squirted everywhere. its happened to me and its happened to my buddy's car. i wouldnt say you have a blows gasket yet. people jump to conclusions way to fast
Old Jul 11, 2006 | 05:30 PM
k3silk's Avatar
k3silk
what is a good way to prevent this?
Old Jul 11, 2006 | 06:24 PM
Julian@MRC's Avatar
Julian@MRC
Doug,
Get the car in when you can for a check up. Could have just overflown out of the resevior tank.I highly doubt you lifted a head at 4 psi, car might have simpy overheated....Did it get hot then go right back down?Or was it running hot for a while??
Old Jul 11, 2006 | 06:28 PM
doug's Avatar
doug
Originally Posted by MRC Motorsports
Doug,
just happened tonight on my way home, 10 min drive, i parked it immediately. It was hot for about 5 mins... I would have to setup to tow it down to NJ.. i don't feel safe driving it to NJ
Old Jul 11, 2006 | 06:32 PM
Julian@MRC's Avatar
Julian@MRC
Doug,
It could have been air bubbles or a thermostat that caused it to run hot. However it could have also blown a headgasket if it was run to hot for to long regardless of EGT's Check the oil and let me know if it is "milky or Murky" looking, like Brownish instead of black or gold depending...Also how is it running since?Has the temps gon back up or did it go right back down after you restarted it?
Old Jul 11, 2006 | 06:36 PM
doug's Avatar
doug
Doug,
i havn't restarted it yet... i will check it tommorow... its too dark out now to check it. I was going to have the thermostat and bubbles in the cooling system checked on Saturday and just drive my jeep for the mean time.
I will let you know how the oil looks tommorow
Old Jul 11, 2006 | 06:40 PM
Julian@MRC's Avatar
Julian@MRC
Kool.
Keep me posted, I really dont think you would have blown a headgasket at low boost levels,I have run from 7-18 psi on a stock headgasket..
Old Jul 11, 2006 | 06:43 PM
doug's Avatar
doug
Kool.
I sure hope so... i will let you know
Old Jul 11, 2006 | 06:54 PM
Julian@MRC's Avatar
Julian@MRC
looks like a boil over, dont think anything is to messed up..Look like some rust from the radiator floating on the surface..
Old Jul 11, 2006 | 07:07 PM
Zivman's Avatar
Zivman
Kool.
Max(chris) sent me the link to this and gave me some background info. If he was running the out of box tune, he could have very well had small detonation occuring since day one due to timing, fuel or both. These small explosions could have worked over the stock head gasket even at those low boost levels.
I had my thermostat go out on my car a couple months ago. while a fair amount of coolant was pushed out, I didn't have anything like what is shown in those pics. That looks fairly violent and the remnants in the coolant are not reassuring.
There is a test kit you can buy that you put on top of your radiator and suck the gases from the cooling system through a solution to test for by products of combustion. I bought and used this to test my car when I was trouble shooting.
I for one don't see this as being a thermostat or air bubbles not being bleed from the system properly. My reccomendation is tear the engine down and drop in some forged internals, get the mating surfaces machined flat, reinstall the TT kit and get a proper tune from the start.
Old Jul 11, 2006 | 07:33 PM
Julian@MRC's Avatar
Julian@MRC
Well this is hard to diagnose over the internet.From the pictures it does not look as violent of a discharge of fluid as you seem to make it out to be, it is limited to the area of the overflow tank. It very well could be the case however only time will tell with a proper diagnosis..
Audible Mayhem's Avatar
Audible Mayhem
My350z
first of all the pics look like the coolant boiled over do to a stuck thermostat or lack of coolant, with a greddy TT kit, the coolant lines run right next to the exhaust manifolds and other places that get really hot. this could easily leak out coolant and cause the motor to overheat
when FI on these motors you really need to watch the coolant temp at all time and if it gets above halfway it needs to be shut down immediately.
if the motor was overheated at all, this could have caused serious damage to the aluminum heads or block. very important to make sure everyone pays attention to the gauge...
Old Jul 11, 2006 | 07:44 PM
Gman2004's Avatar
Gman2004
even better get a after market water temp gauge. you'll see what a POS the factory gauge is once you have an after market temp gauge.
Old Jul 11, 2006 | 07:57 PM
Audible Mayhem
My350z
exactly, watching the UTEC and the actual coolant temp, i notice that the gauge doesnt even move with a 20-30 F degree difference....
WTF
my gauges are on order right now actually...
eat rice z33
man if you let it cool down properly your heads will be fine, to many people worrying about stuff like that, ive seen boilovers left and right for years. dont sweat it. check the fluid level, bleed the system and start her up see how she is. just relax everything will be fine
