V-mount intercooler/radiator
Old Jul 16, 2006 | 02:21 AM
atchernyshev's Avatar
atchernyshev
Question V-mount intercooler/radiator
Team,
can you give recomendation about V-mount intercooler/radiator kit for 350Z
Andrew
Old Jul 16, 2006 | 03:50 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
not really enough room with the VQ...
Old Jul 17, 2006 | 11:22 AM
atchernyshev
thank you
Old Jul 17, 2006 | 06:18 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
there are no kits out there...you would be doing a total custom job with lots of parts needed
Old Jul 18, 2006 | 06:47 AM
Noah@AAM's Avatar
Noah@AAM
check out calvin wan's Falken G35.... he used a koyo radiator with a GReddy I/C and greddy front bumber for cooling and room...now a 350Z....option magazine has made one using the INGS stream front bumper....but yes...everything was and as of now is custom
Old Jul 18, 2006 | 08:16 AM
meatbag's Avatar
meatbag
It can be done with the Vq. Its not really that much less space then with an sr20 swap. You will need to get some sort of aftermarket bumper though so you can get everything at the right angle and it will let you push everything forward some just so it isnt cramped.
Old Jul 18, 2006 | 09:05 AM
Quamen's Avatar
Quamen
There is more room up front then you think. If you made the front end out of tubular chromoly there is no reason that you could not make a v-mount setup capable of 600whp (based on intercooler size) within the confines of even the stock bumper. However, the cost of turbo piping is what would get you. The actual mounting bracket would not be hard to fab up at all.
Old Jul 18, 2006 | 12:40 PM
atchernyshev
thank for all ...
Old Jul 18, 2006 | 02:03 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i have actually been thinking about this, it would be simple, if you took out the whole cross support that holds the radiator and stuff, you could easily do it. i would just make a cross bar for some support to link the two front parts of the frame together.
now retaining the factory AC might be a little harder to do...
Old Jul 18, 2006 | 02:45 PM
World Famous Z's Avatar
World Famous Z
totally custom, it will necessitate a completely new front support. but the airflow should be MUCH better to both the intercooler and radiator alike. I'd recomend getting an underpanel made with vents in it to help pull the air through the lower part of the "V", and perhaps with the hood as well.
Old Jul 18, 2006 | 03:33 PM
chimmike's Avatar
chimmike
https://my350z.com/forum/forced-induction/203936-v-mount-intercooler-radiator.html
atchernyshev
Jul 17, 2006 12:02 PM
atchernyshev
Jul 16, 2006 12:22 PM
