Best FI cam?
Old Jul 31, 2006 | 10:19 AM
mistaboosta's Avatar
mistaboosta
Default Best FI cam?
Hi,
I'm trying to find out which FI cam would suit best with my expectations. I'm looking for a cam that would add the most power while keeping the stock or stock-like drivability of my car. Also I need a shop that makes international sales so that i can get those cams. I'm sending my ecu to AAM next week to have the idle raised to 1000rpm. With addition to my mods below, I've received my Cosworth heads today. Pictures and review soon!
BTW I tried searching on the subject but couldn't find any good info on this.
Old Jul 31, 2006 | 10:38 AM
D350Z10's Avatar
D350Z10
Scott Performance Stage 2 turbo cams!
Old Jul 31, 2006 | 11:18 AM
WA2GOOD's Avatar
WA2GOOD
JWT S2 (stage 2) cams
Old Jul 31, 2006 | 11:20 AM
mistaboosta
i've sent an e-mail to Scott Perf. and JWT but got no response. Where can i purchase their cams?
Old Jul 31, 2006 | 11:22 AM
doug's Avatar
doug
based on what i read.. Scotts
Old Jul 31, 2006 | 11:27 AM
plumpzz's Avatar
plumpzz
Scotts, ive never seen a curve so flat on a FI Z. Flat from 3k-8krpm
Old Jul 31, 2006 | 11:34 AM
mistaboosta
that's good coz i wanna spin that beast to 8K
Old Jul 31, 2006 | 12:26 PM
turismo's Avatar
turismo
Tomei 268's, Scott cams or JWT
Old Jul 31, 2006 | 12:47 PM
D350Z10's Avatar
D350Z10
Tomei 268's are a na cam, to much overlay waste of money for FI.
Old Jul 31, 2006 | 01:21 PM
BrianLG35C's Avatar
BrianLG35C
Originally Posted by mistaboosta
Hi,
Can't wait to hear what the Cos. heads will do.
Old Jul 31, 2006 | 03:30 PM
mchapman's Avatar
mchapman
Im not sure this is the case in practice. The trend at the higher levels of power producing built import motors around the world seems to be towards big lift, high overlap cams to make their power and spin big turbos. And while the specs of the Tomei 268 are biggish with the current selection of cams for the zed they still dont match up to some of the other offerings available for other motors. eg 12mm lift, 272 or 290 duration etc.
I chose the 268s to try to move power up the rpm band and continue to make power over an increase rev limit.
Old Jul 31, 2006 | 03:42 PM
chimmike's Avatar
chimmike
you'll want something wtih as much lift as possible without getting valve slap. Not too much overlap. I'm not a big fan cams like 272s with low lift.......i like something close to a 265-266 with big lift.
I heard the JWT's are good...S1s or S2s.
Old Jul 31, 2006 | 04:07 PM
Bullitproof's Avatar
Bullitproof
Get scotts cams. perfect for turbs. if you wanna get a n/a cam that might work on your car, knock yourself out.
Old Jul 31, 2006 | 04:30 PM
mchapman's Avatar
mchapman
Do you know the specs of the scotts cams so we can try to make a comparison with the other cams on the market?
I know its not accurate as there are alot of things which go into a camshaft profile that arent covered in the numbers but at least that would let us know if they are infact different somehow. Whether that difference is putting out more power or not is up for debate.
It would be great to see back to back dyno figures on the same car with all the cams on the market on a built FI zed. Too much labour to swap the heads, perhaps if a magazine was interested?
Old Jul 31, 2006 | 04:44 PM
craigo'sznprgrs's Avatar
craigo'sznprgrs
how much are these scott performanc stage 2 cams?
Old Jul 31, 2006 | 04:54 PM
mistaboosta
around 1400 i guess
Old Jul 31, 2006 | 06:45 PM
Bullitproof
Don't quote me please. i think they were like 240 duration with 10.25-10.35mm of lift. these are the stage ones. the idle is clean with a slight lope, no idle issues( i didn't adjust the idle at all), and the only cel i get is that pesky misfire on occasion. these cams were meant for f/i!!! I picked up 35whp adding these cam and utec to my car. (boost was increased about .5 psi) the stage ones require no shimming or modifications to install. win-win in my book. check the writeup on my build.
http://www.carv2.com/site/project_detail.cfm?id=443
Old Jul 31, 2006 | 06:48 PM
westpak's Avatar
westpak
SFZCC
I just got a set of new JWT C2 cams (not S2) and will give those a shot when I finish my build.
Old Jul 31, 2006 | 07:14 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
ANYTIME you swap out cams, you are going to want to check the clearances between the cam lobe and the lifters (if that is what you meant by "not having to shim"
You may get lucky and be close, but I have heard many stories of noisy heads when the valves are not adjusted..we ALWAYs adjust the valves anytime we swap in a different cam highly recommended!
+1 for Scott's Cams...very little overlap, spool quickly...the tomei's will ramp up power up top with less timing (i know because i proved it), but I bet the same can be achieved with the Scott's perfromance cams with a bit more timing
TODD
Old Jul 31, 2006 | 07:16 PM
USED's Avatar
USED
Scott cams bar none. Specifically designed for FI.
Stage 1: Great for street. Easy 30-40 whp w/o drivability issues
Stage 2: Usable on the street. More lift = more power
Stage 3: Custom order only. Huge lift/Short duration/Very unique ramp.
Designed to continue power into/passed 8k rpm.
PM me if you can't get in touch with Ted at http://scottperformance.us/
