Pics of Cossy FI Heads (56K - don't even think about it)
Old Aug 3, 2006 | 10:39 AM
mistaboosta's Avatar
mistaboosta
Default Pics of Cossy FI Heads (56K - don't even think about it)
Hi,
Received these heads from Cosworth UK last week. Some time ago I 've sent an e-mail to Mr.Ken from Cosworth USA asking when they will be releasing the FI heads for 350Z and the answer was:
The heads are designed with both NA and forced induction in mind.
The high exhaust flow will help spool big turbos very fast.
Thanks
Ken.
So I asked info about FI heads to my contact in Cosworth UK and I was told that they had 1 set sitting in their facility in Northamptonshire UK. I asked what difference they had and the response was:
Int. Valves and Ex. Valves were resistent to higher EGT temps
Intake: 1250 C
Exhaust: 1000 C
Exhaust runners ported slightly more than the NA heads.
I guess this was all the difference but I'll ask that to Cosworth again to get a more reliable info on this.
I must tell you guys, I've seen Cyl. Heads made in very reputable shops which most of you guys know very well (but no need to tell their names here)
these heads are not even comparable to those.
And the pictures of course.
Old Aug 3, 2006 | 10:49 AM
meatbag's Avatar
meatbag
Those heads look awsome.
Old Aug 3, 2006 | 01:53 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Wow incredible heads, very nice. Can you give us a price range on those? What cams are you running on these heads?
Old Aug 3, 2006 | 02:42 PM
cracka350z's Avatar
cracka350z
shiny....
Old Aug 3, 2006 | 02:43 PM
Zexy's Avatar
Zexy
Sad to see they're gonna go on a freaking motor.. They're a work of art.
Old Aug 3, 2006 | 02:44 PM
Kenk2's Avatar
Kenk2
Professional
I could be wrong, but I heard $6K USD...
bigbri's Avatar
bigbri
Those are going to make some badass power...
Old Aug 3, 2006 | 02:55 PM
turismo's Avatar
turismo
About $4200 minus the cams.
Old Aug 3, 2006 | 03:03 PM
Kenk2's Avatar
Kenk2
Professional
$6K was installed
Old Aug 3, 2006 | 03:09 PM
edwin350z's Avatar
edwin350z
those look pretty!! lol . great looking heads but $$$$$$$$$$$$$$$$$$$$$ wow!!!
Old Aug 3, 2006 | 03:30 PM
cracka350z's Avatar
cracka350z
if i sell my body for you can i have them?
Old Aug 3, 2006 | 03:48 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Just curious...how are other heads not comparable? The heads pictured are ported via a multi angle CNC porting program, correct? I am not a head porting expert myslef, but I have had many a discussion with several, they have all been very adamant that to address the most angles out of a port job, it must be finished by hand..any thoughts? I know we all post pics of heads, they look shiney, some smooth, and oh so metallic ... unfortunately the visual presentation of a head does not dictate its gains...
A head that is CNC machined with little or no human touch will cost less, be more cost effective..but will it be the best flowing head? comments please
TODD
Old Aug 3, 2006 | 03:54 PM
draxxus07's Avatar
draxxus07
il top that, let me drive your car on the weekends and i love you long time
Old Aug 3, 2006 | 07:13 PM
QuadCam's Avatar
QuadCam
high lift flow is not the most important spec..by far. you need to maximize flow compared to the cross sectional area/volume of the runner...essentially, you want the best velocity! additionally, pay attention to flow number at valve lifts. if a head flow outrageous numbers at xxx" lift, but you stock cam doesn't come even close to that much lift, what is the point?
my comments are pointed at the cosworth heads; I am just pointing out facts that people need to pay attention to!!!
Old Aug 3, 2006 | 07:15 PM
QuadCam's Avatar
QuadCam
btw, are these ported stock castings? or are they an entirely new casting?
Old Aug 3, 2006 | 07:23 PM
dkmesa350z's Avatar
dkmesa350z
sexy
Old Aug 3, 2006 | 09:15 PM
mistaboosta
TODD
Todd,
The first thing we shall agree on is that hand P&Polished heads have flaws on them and even with the best job, the runners have some differences between them and this will effect directly the volume of air going in. Also there is no chance of making the same pattern on the ports which will again differ the velocity of air going in thus increasing or decreasing the volume of air going in for each stroke of the cylinder. Another big advantage I saw in these heads againest hand made ones is, angles are not close to perfect in hand made heads. They ARE close to perfect but they are not %100 match in most of the cylinders. All these things will play some role in the power that this engine will make but more important thing is, the amount of air going in every cylinder will be different, which means you won't be tuning every different cylinder correctly (in afr wise) if you don't have 6 O2 sensors working for each cylinder and a standalone to fuel every cylinder seperately. Eventually you'll have leaner cylinders which will be bad for the health of the engine and rich running cylinders which will decrease the power you are making. Seeing close numbers on the flow machine is not a big deal for me coz that will never show the actual flow dynamics of the heads when you will be running them in your car! We've got a pair of nice Supra heads in our shop which we admire the work on them. They are hand made, they are a work of art, BUT they got flaws! The advantage of CNC porting is, angles, patterns, amount of porting is perfectly matched. Maybe the amount of porting is less in CNC heads then some aggressively crafted heads (as CNC heads are a part of serial production like you mention), they will eventually serve more efficiently.
These are my personal opinions, any1 may agree or disagree. Once more I will mention, I'm not trying to bash on anyones work, my honest opinion is CNC machined heads will have much more identical flow between different cylinders, which will produce a safer and higher power (in most cases).
Old Aug 3, 2006 | 09:19 PM
mistaboosta
Looks like I'll be running the Scotts Stg2 cams,
I got the heads for 2200 Sterlins which makes something like 4200 usd.
Old Aug 4, 2006 | 06:09 AM
cracka350z's Avatar
cracka350z
let me smell the heads and ill be your ***** love slave!!!!
beat that!
Old Aug 4, 2006 | 06:13 AM
draxxus07's Avatar
draxxus07
beat that!
