TN kit cat Question?
Old Aug 12, 2006 | 04:44 AM
rs350z's Avatar
rs350z
Default TN kit cat Question?
I have the catted version of the the kit and am actualy on my second cat. The thing just always rattles. b Anyone else with the cat have this issue? I was wondering If i wanted to replace it with no cat what would you guys reccomend I do? Order the pipe from TN or just make my own at an exhaust shop or something?
Old Aug 12, 2006 | 05:37 PM
Peking's Avatar
Peking
Hmmm... Get a different after market hi-flow cat and modify the standered exhaust pipe... Good idea
I was going to order the Turbonetics Cat-Pipe, but I think I will find a aftermarket hi-flow universal cat and cut and weld it to the pipe I already have there.
Also can you take some pics of the set-up? What is rattling exactly? The whole section of that pipe or just the cat?
Old Aug 13, 2006 | 03:33 AM
rs350z's Avatar
rs350z
sounds like the cat also ever since i had the cat on it sounds so "gurgly" when down shifting.
Old Aug 13, 2006 | 08:09 AM
down_shift's Avatar
down_shift
Cat's prob gone again lol.. you have a 12k warranty, just keep using it till you buy a different one lol..
The only thing is.. I think the cat helps the overboost problem since it kind of helps keep the back pressure there... someone can correct me if I'm wrong.
Old Aug 14, 2006 | 06:20 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Why do you even have a cat Roger? Run that puppy catless. You can always drop the cat in for inspection if thats the issue. Maybe TN will replace it with a catless straight pipe for you. Pucker up and make that call.
Old Aug 14, 2006 | 06:29 AM
MIAPLAYA's Avatar
MIAPLAYA
Please do call and have them send a new one. I will talk to Reggie this morning and let him know the cats are having issues. But he needs to log it to provide warranty feedback info.
Old Sep 6, 2006 | 03:41 AM
rs350z's Avatar
rs350z
I guess I didnt know what I was thinking. I recently just drilled/punched out the cat. Putting it on sometime this week, along with 550cc and a retune. Hopefully I dont overboost with no cat!??!? a little nervous about that
Old Sep 6, 2006 | 03:47 AM
taurran's Avatar
taurran
Well, do you have the new wastegate pipe? If you're really concerned about boost levels, go ahead and install it at the same time.
Old Sep 6, 2006 | 07:11 PM
rs350z's Avatar
rs350z
Already got that in. Im must hoping that removal of the cat will change that. Craig do you have a lower wg spring in your car?
Old Sep 6, 2006 | 07:15 PM
taurran's Avatar
taurran
I'm runinng the 7lb spring in the gate, with a blitz boost controller. It holds boost pretty well in lower gears, but will creep slightly in 4th+ to about 9.5psi. I don't have the wastegate pipe in but will be installing it soon (after Z Fest).
Workshop12
Mar 23, 2020 01:45 PM
codek
Sep 28, 2015 03:03 AM
Ace2347
Sep 22, 2015 03:12 AM
juang20
Intake
Sep 7, 2015 05:37 PM
