Just thought some of you might be interested - APS one way valve
Old Aug 15, 2006 | 02:03 PM
Zivman's Avatar
Zivman
Default Just thought some of you might be interested - APS one way valve
Stock PCV's don't necessarily hold boost well. Many leak at over 7 lbs or so. APS is constantly developing products for the Z
Just thought I would share this with you all:
Old Aug 15, 2006 | 02:29 PM
maximumsportZ's Avatar
maximumsportZ
So where do I get one?
Old Aug 15, 2006 | 02:31 PM
taurran's Avatar
taurran
Interesting. I wonder how much APS wants for one of them...
Do they have any data or proof of the stock valve actually causing problems?
Old Aug 15, 2006 | 02:33 PM
maximumsportZ
Should be free for APS owners.
TTRANK's Avatar
TTRANK
+1 on the price.
I assume this would work for any kind of FI?
Old Aug 15, 2006 | 02:40 PM
Zivman's Avatar
Zivman
They tested numerous valves and most were prone to leaking around 8 lbs and beyond -
Hook up an air line to yours and test the pressue it begins to leak at
Old Aug 15, 2006 | 02:44 PM
synth19's Avatar
synth19
where? when? how much???
Old Aug 15, 2006 | 02:45 PM
Zivman's Avatar
Zivman
Old Aug 15, 2006 | 02:49 PM
Zivman's Avatar
Zivman
Originally Posted by TIMMAHH
+1 on the price.
Most; all but TN...........
yes, it will work with all applications
Old Aug 15, 2006 | 02:50 PM
chimmike's Avatar
chimmike
bahahaha, only if installed at an authorized APS dealer
Old Aug 15, 2006 | 02:53 PM
Zivman's Avatar
Zivman
nothing is free in this world - especially not now days
Old Aug 15, 2006 | 10:02 PM
Bullitproof's Avatar
Bullitproof
So, is it avaliable or not? and where can i get it?
Old Aug 15, 2006 | 10:10 PM
taurran's Avatar
taurran
I'd be interested in seeing how much leakage they encountered at boost levels past 8psi. If, for instance, we're talking .01psi leakage at 9psi then I woudn't bother. I'm just wondering if this is really an issue or something along the lines of the shielded CAS.
Old Aug 15, 2006 | 10:30 PM
phunk's Avatar
phunk
CJ Motorsports
cool little product there.
i pressure tested mine last year and it didnt leak, but i cant remember what pressure i tested it to. this is a good thing for everyone to have tho, since its cheap insurance... you wouldnt want to trust that little plastic POS stock one for very long.
keeping pressure out of your crankcase will improve ring sealing, reduce oil consumption, and improved crankcase vacuum can make a little power too.
Old Aug 15, 2006 | 10:34 PM
Weqster's Avatar
Weqster
Or u can just grab a one way valve of any honda out there for nothing. junkyard technology, tested to 40psi+.
Old Aug 16, 2006 | 12:20 AM
phunk's Avatar
phunk
CJ Motorsports
your right, there are 100 other options as well.
the best thing to do would be to actually reroute that entire PCV setup, since it vents to the manifold it will not get vacuum when you want it the most, under boost. It should be ran to a vacuumed catchcan if you want the most complete setup, but thats a lot of plumbing for something that isnt currently presenting an issue.
Old Aug 16, 2006 | 05:00 AM
Gators2001's Avatar
Gators2001
interesting
Old Aug 16, 2006 | 05:12 AM
gringott's Avatar
gringott
vent to atmo. Problem solved.
Old Aug 16, 2006 | 05:35 AM
RBALDINELLII's Avatar
RBALDINELLII
I want one. Come on, tell us where to get them.
Old Aug 16, 2006 | 06:44 AM
QuadCam's Avatar
QuadCam
that is what I did. put a breather on the valve cover (picked it up at Advance auto parts) and stuck a nipple cover on the manifold.
