How many revup's have lost it under pressure??
Old Aug 16, 2006 | 06:08 AM
djParis's Avatar
djParis
Retired Racer
Default How many revup's have lost it under pressure??
I did a search and didnt find any of the results I was looking for. I am curious to see how many guys with boosted revup motors have blown their motors up.
Old Aug 16, 2006 | 06:20 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
dude.. i think im the only one i want my car so damn bad.. wtf this sucks.. i wait way to long. if i didnt have another car this would absolutely suck.
its like its always another week. i get all excited and then no car for you! ONE YEAR! now im ready to move and switch jobs and i still dont have my car.. i have no idea wtf im gonna do.. this sucks.. i sware on everything that is holy i will not mess up this car this time around.. im gonna check and recheck everything everyweek if i have to!
Old Aug 16, 2006 | 06:28 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
and if not the only one.. i was def the first to break a revup motor
Old Aug 16, 2006 | 06:34 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I havent seen a Revup failure besides the guy above. What kit/boost/power did you have?
Old Aug 16, 2006 | 06:37 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
aps tt 8.5 psi 420 rwhp stock block.. spun a bearing
aps tt 12psi ??? rwhp built block destroyed a piston
this time (i hope) 12 psi 500rwhp-ish motor good forever!
Old Aug 16, 2006 | 06:39 AM
plumpzz's Avatar
plumpzz
You were untuned though, weren't you?
Old Aug 16, 2006 | 06:40 AM
QuadCam's Avatar
QuadCam
damn, how'd you destroy a forged piston at 12 psi? did you melt it? too much or too little timing and skyrocket the EGTs?
BrianLG35C's Avatar
BrianLG35C
Did you go with a sleeved motor?
Old Aug 16, 2006 | 06:43 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I know its only speculation at this point, but the rev up motors do seem to be holding up better, as I havent heard of any blow ups, aside from para's. Maybe the internal strengthening Nissan performed is helping?? The rev-up motors are also making about 25whp more with mild boost, when compared to their non-rev-up counterparts. All good news, to me!
Old Aug 16, 2006 | 06:46 AM
QuadCam's Avatar
QuadCam
have you tested an F/I revup with both the stock manifold and a motordyne Mrev + spacer or Mrev 2+ spacer?
Old Aug 16, 2006 | 06:48 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
first time i was tuned.
second time i was untuned and trying to get tuned but had some problems .. so i was driving it back the shop when it went..
Old Aug 16, 2006 | 06:53 AM
Sharif@Forged
Forged Performance
I havent yet. The Rev up motor make power all the way to redline, in most cases, and this accounts for the 25whp bump in power. However, the rev-up motors typically yield a little bit less trq.
Old Aug 16, 2006 | 07:05 AM
TENGAI's Avatar
TENGAI
I've been running my setup since April and haven't blown it apart (yet...). Maybe it's just luck, maybe the revup motors are actually a bit stronger. Not sure. Hopefully I'll have a chance to build the block before she goes (knock on wood).
Alberto's Avatar
Alberto
Cranky FI Owner
My bud has a TN revup but he has the 03' lower plenum and spacer. Worked well NA, but his power is non existant past 6200rpm's, dropped off more than mine ever did. Maybe I should tell him to swap his lower plenum back.
Old Aug 16, 2006 | 07:08 AM
QuadCam's Avatar
QuadCam
i wonder if he spools up fatser w/ the '03 plenum? and what about his torque? although, the TN setup seem to make more torque than all the other F/I setups.
doug's Avatar
doug
JWT makes the most torque PSI for PSI
Old Aug 16, 2006 | 07:13 AM
jpc350z's Avatar
jpc350z
IIRC you were very low on oil??
Old Aug 16, 2006 | 07:25 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I think he spools up later than my car, so no it doesnt seem to help his spool. His TQ isnt as flat either. I think some more tuning is in order to really get a good idea. But Ill run the idea of him putting the stock plenum on to compare.
Old Aug 16, 2006 | 08:46 AM
2fast4thelaw's Avatar
2fast4thelaw
Default Better Designed Rods in Revup
I was reading one of these threads a while back when someone was asking the internal difference in a Revup motor. They evidently redesigned the rods to a stronger design. The pistons are moly coated to for better heat tolerance. I would think this engine would be a better canidate for FI.
I am currently on the waiting list for a Turbonetics ST kit for the Revup.
I am going to get flammed for saying this but you guys that are popping you engines, most of you are asking for it.
Most of these kits are designed and tuned out of the box for a bone stock engine and they tell you not to add engine mods above and beyond the Turbo kit or bad things may happen. About 99% of you guys that have blown your engine have admitted that you have either tweaked with the tuning, adding additional mods thus throwing off the tune, or yoeur street racing and then blame the Turbo kit.
Reading between the lines on these situations its usually very apparent that the problem is the nut behind the wheel.
There is a reason why APS or Turbonetics boldly state "Do not exceed 8.5 PSI or engine failure can occur!",
There is always some wing nut who blindly disregards the warning and jacks it up to 12 or 14 PSI and pops his engine then jumps on this board and either bags on the Turbo kit or the weak stock nissan engine. Then proceeds to tell us all sob story how he's out $5 to 7 grand to rebuild his engine. Then they turn around and do it again! That is idiocy at its finest.
Old Aug 16, 2006 | 08:58 AM
plumpzz's Avatar
plumpzz
You pay to play. Thats why I dont play :-D
