Help With APS TT
Old Aug 27, 2006 | 09:47 AM
Richard Z's Avatar
Richard Z
Default Help With APS TT
Hi
I have a problem with my Z and would like to get some help off you guys.
Spec:- A stock 350Z with APS TT kit fitted an APS test pipes
Symptoms:-
Car Starts fine and idles at 850rpm
The vacuum is 20hg at idle and coming off load
Running 7psi boost.
A/F are fine at idle and under load
The car runs and goes like a dream
BUT
When you rev the engine over 3500rpm and let the accelerator pedal go (the car is stationery) the rpm dive down and the car stalls
When you are going along all is fine until you dip the clutch the rpm dive down and the car stalls. If you let the car cost in gear until you are under 3500rpm and then dip the clutch all is fine.
I have reset the ecu and I have performed a idle air learning procedure, cleaned the MAF.
Any help would me greatly appreciated as I am at a loss as to what it could be.
Many Thanks
Old Aug 27, 2006 | 10:56 AM
failsafe306's Avatar
failsafe306
Are you running the stock map? Mine ran fine on the stock map, but as soon as it was tuned, it started stalling like you're describing.
Old Aug 27, 2006 | 01:35 PM
baileyrx's Avatar
baileyrx
the cause MAYBE the throttle body closing shut when you take your foot off the gas. The engine is now starved for air. Some people(me included) have drilled a small into the throttle body plate, which allows air to get into the engine even with the plate closed all the way. This also helps with poor idle problems from larger injectors.
Old Aug 27, 2006 | 02:24 PM
Zivman's Avatar
Zivman
Originally Posted by Richard Z
Hi
Symptoms:-
Running 7psi boost.
BUT
Many Thanks
My car did this right after my motor build. I was running a half @ss tune while breaking the motor in. that paired with a lightened flywheel caused the car to stall at times (about 3-4 times in 600 miles). After the car was properly tuned, I haven't had any issue. I would get a proper load based tune and I would think it would resolve your issue
Old Aug 27, 2006 | 09:21 PM
Weqster's Avatar
Weqster
Needs better tuning. U can possibly hack around it by increase the idle speed.
Old Aug 29, 2006 | 11:29 AM
Richard Z's Avatar
Richard Z
Hi Thanks for the replies so fare.
Really don’t want to drill holes in the throttle body as this is an expensive bit off kit.
bcoffee20
Nov 19, 2015 06:39 PM
foxsmp26
Sep 25, 2015 09:48 AM
BlinkerFluid
Sep 8, 2015 10:06 AM
ZZZ-35
Dec 30, 2004 05:56 PM
ZZZ-35
Australia/New Zealand
31
Aug 31, 2004 02:53 AM
