Is this pulley normal???
Old Sep 7, 2006 | 12:13 PM
Mr_pharmD's Avatar
Mr_pharmD
Default Is this pulley normal???
I just noticed this today but I cant remember if it looked like this before the vortech sc install. It seems like the pulley is sticking out more than it is suppose to. It's the one with the yellow arrow. Please let me know, thanks.
Old Sep 7, 2006 | 12:21 PM
kevinapex's Avatar
kevinapex
Oh no, thats not right! Looks like the nut has found it's way off.
I think it should have a washer like plate on the front of it also.
Kevin
Old Sep 7, 2006 | 12:29 PM
Mr_pharmD's Avatar
Mr_pharmD
is it safe to drive???
Mr_pharmD's Avatar
Mr_pharmD
thats suppose to be inside more, correct?
Old Sep 7, 2006 | 12:39 PM
kevinapex's Avatar
kevinapex
No, it's the tensioner pulley. I sure wouldn't drive it, or even start it!
The tensioner adjuster bolt needs to be loosened, and that pulley needs to be re-set on the shaft.
I would be real carefull not to start it and have that fall off, it could tear some stuff up.
Old Sep 7, 2006 | 12:43 PM
kevinapex's Avatar
kevinapex
Mine looks like this,
Old Sep 7, 2006 | 01:15 PM
GMZ's Avatar
GMZ
Whoa! I had that same thing happen on mine! I did not put Loctite on it and also forgot to put the washer on it. What I did was push it back to where it was supposed to be, put on washer and nut w/loctite and tighten. Then crank(but dont start!!!) the car a few times to align the belt. Thats what I did. I was a dumbass and was driving around like that to my tuner. Mine looked EXACTLY the same! Crazy. Be careful with that, if that comes off, then youre screwed, as thats not something dealers usually stock. I had broken the tensioner bolt itself and luckily a dealership overnighted me the only one east of the miss. Ahh, the joys of F/I!
Old Sep 7, 2006 | 02:20 PM
Mr_pharmD's Avatar
Mr_pharmD
damn, anyone know the dimensions of the bolt so I can try see if i can find one in the hardware store?
Old Sep 7, 2006 | 05:50 PM
booger's Avatar
booger
I had my tenioner pulley fal off . I had forgotten to tighten it up . Luck was on my side . It fell off right infront of my house and I found the nut
Old Sep 7, 2006 | 08:45 PM
chrisle7220's Avatar
chrisle7220
same thing happened to me, i was at school and when i went back to my car, that tensioner was laying 2 feet away from my front bumper. I could not find the nut, so i basically had to have someone pick me up, drive all the way home, and come back with jack and jack stands to put the damn thing back on. It sucked ***, but i loctited that nut so im sure it'll never come off again, haha.
Old Sep 7, 2006 | 08:46 PM
Mr_pharmD's Avatar
Mr_pharmD
no luck here. I think i have to replace the whole pulley and nut.
Old Sep 8, 2006 | 03:09 AM
GMZ's Avatar
GMZ
Do you have that washer? Its kind of a concave looking thing. Like a pie dish. Just get one of those nut/bolt kits from peps and a bolt that fits should be in there. If not go to Home Depot. How the Ultimate working out for you? A dealer can order individual parts, but they dont usually stock them so you may have to wait a while, or you may get lucky. I imagine that certain components of the tensioner assy are common between VQ's, but ask to be sure. Maybe an Infiniti dealer has one? They seem to have better part stockpiles in my area at least. Check a junkyard for a Max or Alti?
Old Sep 8, 2006 | 09:22 AM
Mr_pharmD's Avatar
Mr_pharmD
I got nada, lol. The EU is working just fine but I seemed to have some misfire at idle and I cant figure out why. I was thinking about throwing in some injector cleaners to see if it helps any (worth a shot).
Old Sep 8, 2006 | 09:27 AM
Eazzy's Avatar
Eazzy
Same thing happened to me
Old Sep 8, 2006 | 09:28 AM
Eazzy's Avatar
Eazzy
The pulley is sold by Nissan ---Bolt --washer etc as a assy ---Not to many $$$$
Old Sep 9, 2006 | 02:50 AM
DMK's Avatar
DMK
From you picture it looks like you tension pulley is still there. It seems the washer and nut fell off which made the pulley come out as it turned. I might be wrong, but that's what it looks like to me. If you know how to loosen the belt, do that and try to wiggle the pulley back in as is should still be connected to the tension bolt. Then buy a washer and nut at a local parts store.
Old Sep 9, 2006 | 06:00 AM
Mr_pharmD's Avatar
Mr_pharmD
The bearing was messed up so I had to order a new pulley from nissan. Hope to have her running on monday.
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
codek
Sep 28, 2015 03:03 AM
