few questions about the APS
Hey everyone,
Just wondering if some of you might be able to help me with a few questions I'm having. Currently I'm looking at going FI with my Z. The question I have is, I want to make around 800rwhp on full boost, on a completely built engine with the boost jacked up would the APS Twin Turbo Kit be able to put down 800rwhp? Or would you recommend just going with the new APS Extreme Kit? Thank you for all your help!
-Travis
DFW/STL
-Travis
DFW/STL
Definitely go with the APS Extreme Kit. The standard kit is only good for about 680whp and you'd be wasting money on the fuel system, injectors, and unichip which would all need to be upgraded.
From what I understand, people are making over 700whp on the basic APS turbos with upgraded actuators/fuel system/ems.
Originally Posted by skidmarq
I'm just curious, what your goals are with that 800WHP?
Originally Posted by sugarspunZ
+1 i cant imagine that much power. what would anyone do with it? i would imagine the car would be almost impossible to drive on the street.
you think 400 is enough till that mustang beats you; you upgrade....you think 500 is enough till that supra beats you; you upgrade...it never ends....ever.....
make it stop...........ahhhhhhhhhhhhhhhhhhhhhhhhhh
Originally Posted by mrtomcat
It's called Drag Racing....it's fun, addicting and almost as good as sex
lolol, you make it sound like crack......maybe it is for some people, but i am also interested in why 800hp?
Yes just don't go over 10 pounds of boost
i wonder how many people have really been in a car with that much power.
i mean could one really drive to work in traffic with 800whp?
I guess I just wanted to understand why the OP has an 800WHP goal (as opposed to 400 or 500) so I can gauge whether or not the OP also understands that controlling that amount of power will require quite a bit more than just planning the appropriate turbo kit (i.e. tires, camber, axles, potential widebody kit to accommodate the huge tires, etc)...
In all seriousness I would not want to drive an 800 whp car as a daily driver but that's what maps are for.
You have let's say a 400whp map for your daily and when you go to the track you flip a switch put on slicks and kick booty.
Another reason to get that type of setup is room for growth and stability
I'm getting a block that can hold that much power so that it won't break as easily on lower settings. The abuse will be less
make sense?
make sense?
Dude you are so right! I have over 460hp and it is not enough. I just got off the phone with Sharif to schedual my drop for my engine build. When does it stop??
make sense?
Originally Posted by baptist
Sure does, hows it all going tomcat?
Mine should be firing up this week, all being well.
I'm probably going to pick it up in the next few days to break in the block for a week or two and then bring it back, have them replace the springs, finish the tune and then install the dreaded roll bar which is turning out to be a nightmare in itself.
I miss my baby.....
