low compression engine question
Old Sep 14, 2006 | 04:33 PM
baileyrx's Avatar
baileyrx
Default low compression engine question
what is your vaccuum at idle?
I just noticed its stays around negative 9-10.
It used to be about 15- 19.
I hope this is normal
Old Sep 16, 2006 | 04:57 AM
booger's Avatar
booger
Ive got nismo cams and 8.5 to 1 pistons and vacuum at idle is 10 to 11 . But I think it has more to do with the cams than the compression . Not sure
Old Sep 16, 2006 | 07:02 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
mine is at 11-12 at idle...double check all the vacuum lines...this could be normal/is your gauge dead on when the car is off? (at 0)
what boost are you running? is it tuned yet?
Old Sep 16, 2006 | 07:39 AM
Zivman's Avatar
Zivman
mine is 18 or so
Old Sep 17, 2006 | 09:32 AM
sandy@forged's Avatar
sandy@forged
Forged Performance
Are we talking PSI or mmHG.
I usuallyi see between -7 and -10 psi....depending on the cams and compression ratio. Lower CR engines, or higher lift/duration cams will result in slightly less vaccum.
Old Sep 17, 2006 | 10:07 AM
baileyrx's Avatar
baileyrx
yep, found it.
i havn't fully connected my blitz boost controller to my wastegates!
I figured the selonoid would stay closed, pfff what do i know, anyways,
the car idled fine, just thought it was odd.
now time to set a tuning appt......
Old Sep 17, 2006 | 10:25 AM
Eazzy's Avatar
Eazzy
When ur Cammed out u generally have a drop in vacuum due to overlap, But I dont know that the after Market Z cams are that radical. Chk for vacuum leaks. Chk with MIA ------ U were too quick for me !!!!
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
bcoffee20
Nov 19, 2015 06:39 PM
_koubie_
Sep 20, 2015 06:34 PM
