question about THIS turbo
Old Sep 19, 2006 | 02:39 PM
Lo$t's Avatar
Lo$t
Default question about THIS turbo
if i put this directly onto my car, would i need internal work done or would it safely operate stock? if i do need work done, what would be some good measures?
link to the turbo
http://www.stillen.com/product_detai...?sku=TURB15134
Old Sep 19, 2006 | 02:48 PM
sinister350z's Avatar
sinister350z
should be direct bolt on. It does come with recalibrated ECU and fuel injectors, so you should be safe if your at a conservative boost level. Id say about 7-9 psi you should be ok. Im not a 350z pro but I have had a few turbo cars in the past and know what to look for. As long as you have plenty of fuel u should not detonate. Just my 2 cents
Old Sep 19, 2006 | 02:51 PM
MIAPLAYA's Avatar
MIAPLAYA
I've been running that kit on my car for 40k miles. Stock internals. No issues for 40k miles.
Old Sep 19, 2006 | 03:37 PM
JETPILOT's Avatar
JETPILOT
link to the turbo
If no modifications are made to the kit it will be fine on a stock motor. I never heard of anyone blowing their motor on an unmodified kit on a stock car if everything is installed correctly with a dyno run to check A/F ratio.
Lo$t I sent you a private message.
JET
