Forge Actuator WOW!!
Old Sep 26, 2006 | 08:35 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Then your forge actuator's thread is too long. I only turned 5-7 times in order to get the rod to be one hole shorter.
Originally Posted by tig488
thats what im talking about, the rod specs, i know the cannister and springs are the same, im wondering if the rod length or thread length is different. somebody posted pics of their setup and they had a forge cannister, but had the stock rod on it. i looked at mine and there is no way in hell the stock rod will fit on it. my threaded rod is too long, if i put the stock rod on my forge cannister, its so long, there wouldnt be any tension on the wg swingarm.
Old Sep 26, 2006 | 08:40 PM
Bullitproof's Avatar
Bullitproof
you think that might help get the correct preload on my wg, right now like i said i have the short rod tightened all the way down till it wont go anymore, but maybe that is preventing me from achieving the right preload. im gonna call luis at forge tomorrow and see if he can ship me the right one, if not, ill send you mine.
Call James at carv2. we just finished the tune with the aps st exhaust and ended up with 445whp and 430trq. i got the boost graph and except for a 5500rpm bump(cams probably), the boost curve is pretty smooth. if i can't get to a scanner i'll just take a pic and send you the graph.
Old Sep 26, 2006 | 08:42 PM
Bullitproof
we modified the rod so we could get more tension on the actuator. works fine for the aps st.
Old Sep 26, 2006 | 08:44 PM
MadBoost's Avatar
MadBoost
Exactly, and you should have more thread available to go with even more preload if necessary. The pic of Tig's actuator is a completely different setup where the attachment arm is short and only has about an inch of depth of female thread and is bottoming out to early in it's adjustment. I am concerned whether it was actually allowing the wastegate door to fully shut and if so, how many turns before the attachment arm bottoms out on the threaded rod.
Old Sep 26, 2006 | 10:49 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Mine doesn't look like your's. I use the original APS rod just like the first picture you posted.
But....
Even with your long thread setup, as long as you can shorten it a hole or two length and pull the rod (preload) to mount it on the internal WG arm, it should work the same way.. shouldn't it?
Old Sep 27, 2006 | 03:15 AM
tig488's Avatar
tig488
the flapper is closed, i can get several turns on it before it bottoms out, but i dont think its a complete hole length, im gonna call forge, does mike work at forge?
Old Sep 27, 2006 | 05:59 AM
MadBoost's Avatar
MadBoost
I just talked to Luis @ Forge and explained the scenario. He is just waiting for you to give him a call.
Old Sep 27, 2006 | 06:08 AM
BrianLG35C's Avatar
BrianLG35C
Originally Posted by Sharif@Forged
Absolutely. You will have trouble getting more than 10psi out of the stock APS actuators. I struggled to get to 8.5psi with a customer's car last week...using a UTEC and Blitz SBC-iD. He did have a restrictive exhaust/downpipe setup, so that contributed to it. But for high boost, the upgraded actuators are a must.
Gotcha! So what is the maximum psi you've gotten out of a APS TT with the Unichip, upgraded actuators and exhaust? I know GRD reached 500whp with the APS 2.5" exhaust but that was on a Dynapack.
Old Sep 27, 2006 | 06:57 AM
tig488's Avatar
tig488
thanks man, i just hung up with him, hes gonna ship me out a while new actuator setup, not just a rod, pretty cool of those guys.
Old Sep 27, 2006 | 08:55 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
14psi.....customer didnt want any more than that. I believe MRC has gotten about 16-18psi out of theirs.
Old Sep 27, 2006 | 09:00 AM
BrianLG35C's Avatar
BrianLG35C
Really? And that's with the stock APS TT fuel system? What whp did you get at 14psi? So you're tuning the Unichip now?
Old Sep 27, 2006 | 09:58 AM
Valerie@Forged's Avatar
Valerie@Forged
Forged Internals.com
I'll have valerie add them to the website...we sell at lot of them.
Done
http://www.forgedperformance.com/sto...1&cat=0&page=1
Old Sep 27, 2006 | 10:24 AM
Nismo350ZRT's Avatar
Nismo350ZRT
Originally Posted by Valerie@Forged
Valerie, that's for a pair right?
Old Sep 27, 2006 | 10:34 AM
Sharif@Forged
Forged Performance
That's for each....unless they recently changed their pricing and didnt tell us. Lemme know if it looks out of line.
Old Sep 27, 2006 | 10:35 AM
Sharif@Forged
Forged Performance
No, this was with a full return fuel system, 550cc injectors, and a UTEC.
Old Sep 27, 2006 | 10:52 AM
tig488's Avatar
tig488
thats probably right, i paid close to that for my single actuator.
Old Sep 27, 2006 | 10:58 AM
Nismo350ZRT
I thought I read ppl buying them for $250 pair. Guess I was mistaken.
Old Sep 27, 2006 | 11:50 AM
  #38
BrianLG35C's Avatar
BrianLG35C
Ok, that makes sense. Any update on you becoming an authorized Unichip tuner?
Old Sep 27, 2006 | 12:57 PM
  #39
Sharif@Forged
Forged Performance
We are going to become Unichip Q tuners, not regular Unichip. In all honesty the basic Unichip is a very crude platform. I have no doubt it can run engines safely, but its not going to be worth the high software/training costs, in order to run the system. We also need to run it on a Windows95 laptop....can anyone say EBAY?
Old Sep 27, 2006 | 06:21 PM
  #40
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I wonder when Peter at APS will switch over to Unichip Q for the APS ST and TT kits. Will they? I haven't tuned my Unichip since there is no unichip tuner in Korea.
Fortunately, Destek Unichip Q tuner just opened business in South Korea. Once the Unichip Q is available for the APS ST, I can purchase the Unichip Q from Peter, and get it tuned...
