C16 and a little more boost...Tuning update!
Old Oct 1, 2006 | 02:00 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Default C16 and a little more boost...Tuning update!
So before I switch out to a stage II fuel system, and even larger injectors, I wanted to see what the current setup could do.
So earlier in the week, I tuned my engine to 575whp (STD Atmospheric correction...pure Dyno Dynamics numbers) at 16.5psi on 93 octane pump gas, which, IMHO is the absolute maximum one can safely acheive on pump gas. Figure roughly 8-10% more on a DynoJet.
Last night, we drained my tank, and added 10 gallons of C116. After a few more passes, we managed 629whp@17.5psi
I REALLY need to upgrade my downpipe setup. Believe it or not, the only Forged Performance 3inch downpipes in existence...are on Alberto's car. We are in the process of making 10 sets, and I could definately use them. It was unsafe to proceed any further without completely eliminating exhuast backpressure issues.
Oh, I also switched to the 18's TE37's with Hossiers all around....just for racing. I spent most of last night and early this morning messing around on the street. The car finally HOOKS UP.....its unreal. 100% hookup in 3rd-6th gears with 600whp+ is a LOT of fun.
So that's about it for now. Next steps, are installing the Level 2 fuel system, 750cc injectors, HKS FCON V-Pro, and 3inch downpipes. Stay Tuned!
Summarized Recap of mods:
Greddy TT Kit w/ TD06/60-1 upgrade
Darton Sleeved Block to 3.8L
Arias ED pistons 9.0:1
Pauter Rods
GTM Stage 3 Heads: Full Oversized Ferrea Valvetrain package
JWT S1 Cams
UTEC Engine Management
ATS/Across Carbon Triple Disc Clutch
ATS Carbon LSD
DSS Level 2 axles
Return Fuel System w/ 650cc RC Injectors
Hope everyone had a good/safe weekend.
Sharif
Old Oct 1, 2006 | 02:09 PM
savvy's Avatar
savvy
thats gross
Old Oct 1, 2006 | 02:12 PM
Mike Wazowski's Avatar
Mike Wazowski
Sick numbers Sharif
Nic@CiNcity's Avatar
Nic@CiNcity
Are you going to be selling those 3" down pipes? I could use a set VERY soon.
Old Oct 1, 2006 | 02:15 PM
Sharif@Forged
Forged Performance
Yes, once they are 100% done...they will be added to the website. We are probably going to have a re-circ option as well, since open dumps attract too much attention for most people.
Old Oct 1, 2006 | 02:34 PM
QuadCam's Avatar
QuadCam
sharif,
any chance you are going to work on a solution for the TurboNetics ST backpressure issues?
Old Oct 1, 2006 | 02:35 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Like I told you on the phone thats nasty. I couldnt imagine 90 more whp over my high boost, just sick, even more amazing your running those little Greddy downpipes. Like always amazing job...curious to where you hit full 16.5psi/17.5 psi boost at?
Old Oct 1, 2006 | 02:36 PM
rs350z's Avatar
rs350z
Originally Posted by QuadCam
sharif,
yah it is called Greddy TT Sweet numbers! I bet you that thing sounds incredible
Old Oct 1, 2006 | 02:37 PM
Alberto's Avatar
Alberto
Cranky FI Owner
sharif,
Why would he spend time doing that when TN is doing R&D, and putting out the Stage 2 come SEMA...
Old Oct 1, 2006 | 02:41 PM
Nealoc187's Avatar
Nealoc187
Pauter Rods
JWT S1 Cams
ATS Carbon LSD
DSS Level 2 axles
Sharif
Excellent numbers. In addition to the extra pound of boost, is it safe to assume you altered timing on the C16? If so, are you willing to discuss how much you added and where in the map?
Old Oct 1, 2006 | 02:49 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
good job ,keep up the good work .
Old Oct 1, 2006 | 02:53 PM
Nic@CiNcity
Rather than go OT, i sent you a PM. You seem like the man to talk to about the question i got.
Old Oct 1, 2006 | 02:56 PM
sean350z06's Avatar
sean350z06
i am deff gonn come up and see sharif to do my set up, do u feel that going up to the 3.8 was worth it?
Old Oct 1, 2006 | 03:01 PM
Sharif@Forged
Forged Performance
Thats correct. With just the addition of C16, the AF ratio dropped about 3/4 of an AF point richer. I did add timing, but the trq curve didnt suit my comfort level, is I didnt bother going too high with the timing, or even higher with the boost. We have a very thorough and methodical tuning process; consistency and predictability is very important. When things don't look or feel right...I will never continue. There is plenty of time for more power later.
Sam, "West Coast VQ35 tuning Guru" Thanks buddy!
Old Oct 1, 2006 | 03:04 PM
baptist's Avatar
baptist
Brilliant results.
Sharif@Forged
Forged Performance
Not really sure just yet. The engine and turbo upgrade are producing more power than would otherwise be expected at this boost level, but I dont know if the turbo upgrade is the cause, or the overbore..or the GTM StageIII heads. I changed too many things at once! My inclination is to stick to 96mm bore, and just upgrade the turbos and run more boost.....but I am not convinced either way.
Alberto's car made superb power with the 3.5L block, and stock Greddy turbos.
Old Oct 1, 2006 | 03:06 PM
Sharif@Forged
Forged Performance
sharif,
As Alberto alluded to, TN should be ready with their tested StageII setup, and that should solve the issue. I am going to be finishing up and tuning JETPILOT's setup, and we'll see if the fixes he implemented, will help the issue. If not...StageII should be coming in the fall.
Old Oct 1, 2006 | 03:16 PM
Nealoc187's Avatar
Nealoc187
Can you say how much timing advance you added?
Old Oct 1, 2006 | 03:25 PM
Gumpdriver's Avatar
Gumpdriver
Great numbers, can't wait till you turn up the boost. LOL
Old Oct 1, 2006 | 03:31 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I'd assume since he didnt answer the Q the first time its a "secret"
