TN guys w/ the WG relocation...how much PSI???
Old Oct 2, 2006 | 09:29 AM
QuadCam's Avatar
QuadCam
Default TN guys w/ the WG relocation...how much PSI???
this question is to all the guys with the turbonetics kit. If you have installed the wategate relocation pipes, what is the highest psi you are seeing?
1) Quadcam 9.5 PSI (stock block revup engine)
Old Oct 2, 2006 | 09:35 AM
MIAPLAYA's Avatar
MIAPLAYA
2) MIAPLAYA 8-8.5 PSI (no wastegate relocation pipe)
Old Oct 3, 2006 | 11:52 AM
ZIABLO's Avatar
ZIABLO
I am Batman
I'm seeing 10. And it's pretty consistent so I dunno
Old Oct 3, 2006 | 01:13 PM
rs350z's Avatar
rs350z
10.5 (w/ relocation)
Old Oct 3, 2006 | 04:11 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
I was seeing aroung 10.5 until recently. I got a replacement turbo due to blown seal. So far at least I have not seen over 8.5. Not sure what to make of that.
Old Oct 3, 2006 | 05:57 PM
Ace Ventura's Avatar
Ace Ventura
8-8.5 without relocation.
Old Oct 3, 2006 | 06:18 PM
Gumpdriver's Avatar
Gumpdriver
8-9.2 psi with out the relocation.
Old Oct 3, 2006 | 06:28 PM
QuadCam's Avatar
QuadCam
strange how we are all getting very different numbers.
Old Oct 3, 2006 | 06:51 PM
MIAPLAYA's Avatar
MIAPLAYA
Have everyone list all mods on the car and I bet no one who has posted yet has the same setup.
Old Oct 3, 2006 | 07:20 PM
JETPILOT's Avatar
JETPILOT
It's all based on the exhaust. The better your exhaust flows the more you will overboost.
JET
Old Oct 3, 2006 | 07:38 PM
taurran's Avatar
taurran
JET
Well that should be fixed with the wastegate relocation pipe. If people are still experiencing this after the relocation is installed, it's most likely another issue.
I'm personally not runnning the wastegate pipe, but I see about 8.5 psi when dialed in for 8psi on my ebc, and 9.5psi when I'm dialed in at 9psi. I only get this if I run in 4th gear and up.
I'm going to be installing the wastegate pipe soon which should fix everything.
Old Oct 3, 2006 | 07:49 PM
MIAPLAYA's Avatar
MIAPLAYA
JET
That would be true if you didn't have the overboost pipes installed. But Turbonetics installed the overboost pipes on their G35 with the Topspeed Pro-1 that you have and did not go over 8.5 PSI. RedHotZ installed it on his Z with an RSR exhaust and no more overboost there either.
Old Oct 7, 2006 | 07:02 AM
down_shift's Avatar
down_shift
8.5-10psi Fuji Exhaust, relocation pipes
Old Oct 7, 2006 | 07:07 AM
ZIABLO's Avatar
ZIABLO
I am Batman
my boost shows 10-10.5psi with wg relocation and overboost pipe
Old Oct 7, 2006 | 07:18 AM
titankiller's Avatar
titankiller
Bought my kit about two weeks ago new and can not get over 6.5lbs. I will have to contact TN for some info and the low boost!
Old Oct 7, 2006 | 07:56 AM
freezeg35's Avatar
freezeg35
does anyone know how the reflash handles the overboost. Im worried that the reflash only adresses timing and boost up to a certain point like maybe 9 psi.
Old Oct 7, 2006 | 10:45 AM
MIAPLAYA's Avatar
MIAPLAYA
The flash has handled as much as 11 PSI in the past... Turbonetics doesn't recommend over 9.5 PSI though.
Old Oct 7, 2006 | 01:41 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
I got to do a lot of driving and boosting today...I hit 10.1 psi.
Old Oct 11, 2006 | 07:33 PM
rs350z's Avatar
rs350z
new pic....
Old Oct 11, 2006 | 07:34 PM
rs350z's Avatar
rs350z
thats eleven!!!!!!!!!!!!!!!!!!!!!!!
