APS ST only making 351whp and 320tq
Old Oct 3, 2006 | 01:13 PM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
Originally Posted by azula
350 to the wheels is what to the flywheel? 400? and the flywheel hp is the one they publish on car commercials and such right?
If you use a 18% loss @ the wheels then the brake horse power would be 427 hp @ the flywheel (used for advertisement purposes).
Old Oct 3, 2006 | 02:16 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Originally Posted by Sharif@Forged
Ask Sam if he experienced the boost drop that everyone else has been dealing with. If so, those numbers are about right.
no boost drop on this car,the horse power # are @ 7 PSI .the car would not do more than that on the dyno ,so 351whp @ 7 PSI on 91 octane .with 11.4 AFR IS excellent in my book,with the boost gage on the windshield on a test drive the car did 9 PSI constant no drop .
Old Oct 3, 2006 | 02:33 PM
iyah's Avatar
iyah
Originally Posted by RED HOT Z
Well I dont know much about that kit but Sam at GT tuned my car and I made 384whp and 380wtq on a TN ST.
looks like you went with the wrong kit
j/k
BURNED!!!
Old Oct 3, 2006 | 03:14 PM
sugarspunZ's Avatar
sugarspunZ
What causes the discrepancy in psi. you said the car dynoed at 7psi but the gauge says 9psi. I am just trying to understand.
Old Oct 3, 2006 | 03:26 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
very good numbers, then..for just 7psi. Different boost gauges can read differently. It's not uncommon to see a psi difference between gauges, and maybe in the different gears, or under different loads, you are experiecing a little bit more boost.
Old Oct 3, 2006 | 03:55 PM
sugarspunZ's Avatar
sugarspunZ
i see i see.
does anyone know when the APS external waste gate is comming out. GOD DAMN i want one.
Old Oct 3, 2006 | 04:25 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
same gauge different conditions ,7 PSI on the dyno and 9 PSI on the road .since we are using a dyno jet ,it is impossible to get a true load ,like when you are driving on the street .and don't forget turbo charger's boost is directly linked to exhaust flow so the more exhaust you are creating by having more load the more boost you are going to have available .
Old Oct 3, 2006 | 04:49 PM
sugarspunZ's Avatar
sugarspunZ
that makes since. thanks sam
Old Oct 3, 2006 | 05:36 PM
RNB419's Avatar
RNB419
Gt motorsport <---best shop in the world.
Im such a retard. i burned my clutch like crazy after trying to race an M3. Master Sam says exedy stage one & flywheel, and thats the one im gonna install.
Old Oct 3, 2006 | 11:11 PM
Bullitproof's Avatar
Bullitproof
Originally Posted by Alberto
Cams isnt a cost effective mod that most ST guys do unless the motor is out and getting built. You cant act like its an easy/typical mod. BTW-115mph trap even in a G doesnt impress anybody with the power your pushing-Im curious to what you ran in that set-up at that trap, low 12's Id hope.
Not saying its easy oh great one-just doable. yeah it was low 12's. and last time i checked my g35 checks in at 3600lbs, add 100 lbs. in audio and 200lb. driver on the track for the first time in a rear wheel drive car and thats what you get. now once i get more time behind the wheel and click off 11's, i'll put it in my sig like you slick.
Old Oct 3, 2006 | 11:15 PM
Bullitproof
Originally Posted by Oleg
Looks like someone wants a TT performance for an ST price...
well since my car is built with my money, yeah i guess you are right oleg. not all of us can just write a check for 20k. but all that will be rectified this winter. if that comment was directed to me, that is. if not, my apologies.
Old Oct 4, 2006 | 04:39 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I have the same result... 7psi 354 WHP ~11.5AFR on DJ. On road, I see 10.5psi and who knows what WHP????????????? Same Zeitronix boost gauge... I need to dyno it on some other dyno machines... Just curious though.. other APS ST owners report 380~440WHP on DJ.... Are there load based Dynojets as well?
The one I dynoed is not load based for sure.
Old Oct 4, 2006 | 07:16 AM
Bullitproof
i see i see.
Probably not for a while. unfortunately.
Old Oct 4, 2006 | 07:20 AM
Bullitproof
At 9psi without cams i made around 385whp with a safe tune. so for 7psi your numbers seems about right. heres a link to some general info on my car.
http://www.carv2.com/site/project_detail.cfm?id=443
Old Oct 4, 2006 | 07:54 AM
ChromeZilver's Avatar
ChromeZilver
So on a stock motor you made 385whp at 9psi? That's sweet.
Old Oct 4, 2006 | 08:57 AM
doug's Avatar
doug
why is that sweet?
Old Oct 4, 2006 | 12:35 PM
Bullitproof
Why are you hating Doug? These numbers arent super, but are numbers that are about average for that kit. if you know someone making more than 400whp at 9psi with an aps single turbo kit, let me know. if your just aps hating for the hell of it, just stay off the thread. no reason to pollute this thread with your negative comments.
Old Oct 4, 2006 | 12:44 PM
  #38
Oleg's Avatar
Oleg
Appology accepted, it was not directed at you.
Old Oct 4, 2006 | 12:47 PM
  #39
doug's Avatar
doug
woah woah woah.. back up bud.. i am not hating or issuing negative comments.. i am just asking why is that sweet... i actually think those numbers are average.. not sweet
Old Oct 4, 2006 | 01:31 PM
  #40
tig488's Avatar
tig488
oleg cant talk, hes been talking about going FI since he joined the site, he just hasnt stepped up yet.
