Turbonetics Tuner Kit
Old Oct 3, 2006 | 03:31 AM
mrkplatt's Avatar
mrkplatt
Default Turbonetics Tuner Kit
I'm looking at the Turbonetics Tuner Kit for my 2004 350Z Roadster. Seems like the most complete kit out of the box and gives a good bang for the buck. I'm not doing anything extreme with my Z, but want to wake it up a bit.
Any experience out there with this kit? I was going to also do the fuel upgrade they recommend.
Any recommendations on other add-ons that should be considered besides the Single Turbo Kit and the Fuel Upgrade?
Is there a better way to go to get to the HP ratings of this FI Kit (450).
Thanks,
Mark
Old Oct 3, 2006 | 05:25 AM
QuadCam's Avatar
QuadCam
you'll need to get a UTEC or similar engine management system.
Old Oct 3, 2006 | 05:26 AM
Gumpdriver's Avatar
Gumpdriver
UTEC, Return fuel, and a great tuner
Old Oct 3, 2006 | 07:31 AM
JETPILOT's Avatar
JETPILOT
You will need:
UTEC w/map (Manifold Air Pressure) sensor
Deatschwerks 440 injectors
Walbro 255 fuel pump
TN tuner kit
Tuning
Installation
A good exhaust and a stronger clutch are also recomended but not required. You will not need a return fuel system. A return fuel system is a nice thing to have if you are planning over 400 whp. The tuner kit @ 8psi of boost will likely give you between 360-380 whp. The overwhelming majority of the TN kits make 365-370 whp. You might think about adding an exhaust as well. The stock exhaust is horrible for turbo installs.
JET
Old Oct 3, 2006 | 03:35 PM
VIZAGE's Avatar
VIZAGE
+1 on UTEC.
EnjukuRacing
Sep 30, 2015 06:55 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
