Can traction control hurt the motor?
Old Oct 12, 2006 | 04:57 AM
ken350z's Avatar
ken350z
Default Can traction control hurt the motor?
Doesn't traction control work by lowering the fuel? Could the A/F ration get too lean and cause pre-detonation?
TIA
Old Oct 12, 2006 | 05:23 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Id say no, its just like when you hit limiter its not going to blow your motor. But I wouldnt advise to be hitting it all the time. When I plan on boosting I turn off the VDC, anything in the first 4 gears at WOT and it kicks in....
Old Oct 12, 2006 | 07:40 AM
Black_Sunshine's Avatar
Black_Sunshine
TCS works by reducing throttle opening when it detects drive wheel slippage.
Old Oct 12, 2006 | 08:03 AM
Alberto's Avatar
Alberto
Cranky FI Owner
VDC is different than TCS, I was reffering to VDC for the record
Old Oct 12, 2006 | 08:07 AM
garyovich's Avatar
garyovich
this is slightly off topic, but i was wandering if you all notice a big acceleration difference on clean, dry pavement with traction control turned off. a friend of mine and i are forever arguing this point.
Old Oct 12, 2006 | 10:21 AM
Dirty Dave's Avatar
Dirty Dave
With twin turbo's, methanol injection, and a built motor, yea I guess you can say I notice big acceleration on dry pavement . I think you are talking about in stock form right ? When I was stock it did seem to have more acceleration with vdc turned but its probably all just in our heads .
Old Oct 12, 2006 | 11:49 AM
perrogrande007's Avatar
perrogrande007
On my NA car I can't feel a difference.
Old Oct 12, 2006 | 12:08 PM
sisco534's Avatar
sisco534
TCS is a booger, I have same size wheels all around and if I come around a curve a little fast it comes on not because I have slippage but becuse the computer thinks it is spinning!!! I turn it off every time I get in the car except when it is raining or it spins like crazy. I dont think it would make your engine detonate. It is a program in the ECU.
Old Oct 12, 2006 | 09:33 PM
FrickU's Avatar
FrickU
It shouldn't make a difference, but yes if you are boosting a lot and putting down good power there is a good chance of spinning like Alberto stated. I always turn it off myself, I feel safer when there isn't a slip sensor that could hold me back.
Fixxxercask
Nov 9, 2015 11:10 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
