Larger TB for higher power applications?
Old Oct 12, 2006 | 09:57 AM
chimmike's Avatar
chimmike
Default Larger TB for higher power applications?
I ran a search and wasn't able to find if this had been covered yet. I've noticed most 500+whp builds utilize the stock throttle body. I'm sure there's been consideration to upgrade but I haven't found anything here discussing it.
IIRC the stock TB is something like 70mm or so? I searched on that and wasn't successful (stick a fork in it and just show me the thread in case it was that obvious and I missed it, lol).
Anyways, in the idea of opening up all possible restrictions, I think a TB upgrade would be tantamount to this if the entire plenup is polished and extreme headwork is done.
Opinions? Information?
Thanks
Old Oct 12, 2006 | 10:38 AM
Alberto's Avatar
Alberto
Cranky FI Owner
There are a few TB options but none I really like. They are large at opening and taper down to stock by the time it bolts to the upper plenum, not a straight through overbore like most other applications. Also, because these TB's can be finicky with their mechanisms failing (earlier Z's) not many want to swap or spend $$$ and do it and have the TB fail shortly after.
Old Oct 12, 2006 | 11:05 AM
clemlover15's Avatar
clemlover15
I can't be a 100% sure here but the Q45 infinity TB is larger and may fit, and operate like stock???
Old Oct 12, 2006 | 11:18 AM
sisco534's Avatar
sisco534
Crawford is working on a larger TB.
Old Oct 12, 2006 | 11:20 AM
chimmike's Avatar
chimmike
good to hear about crawford.
I mean obviously the only reason there aren't people running bigger ones is the DBW issue. I know that it's extremely touchy and a real PITA to deal with..........
the Q45 might be do-able if the DBW control is compatible and the tps can be reset.
sales@czp
Sep 23, 2019 03:30 PM
