Aps St Question
Old Oct 19, 2006 | 09:11 PM
  #61
sugarspunZ's Avatar
sugarspunZ
Originally Posted by spracked
are cars are cursed sugar!
i am about ready to throw in the towl and just buy a totally different turbo. god, i have not been over 90mph in about a month. i need a drink.
Old Oct 19, 2006 | 10:07 PM
  #62
spracked's Avatar
spracked
sugar is your car at gt or do you have it at home?
my car has been down for almost a month now, im going threw withdrawls.
Old Oct 19, 2006 | 10:10 PM
  #63
sugarspunZ's Avatar
sugarspunZ
its at GT. GT is its new home
Old Oct 19, 2006 | 10:16 PM
  #64
spracked's Avatar
spracked
i have a feeling my car and your car are going to become good friends
Old Oct 19, 2006 | 10:21 PM
  #65
sugarspunZ's Avatar
sugarspunZ
i have a feeling mine is going to be there for a few more weeks. however when i get it back, i am sure it will be running infinitely better.
Old Oct 20, 2006 | 02:46 PM
  #66
spracked's Avatar
spracked
so good news, the car is smoking less and less which is good. I guess something with the unichip wasnt ziptied correctly so it wasnt reading very well. now we are making close to 9lbs! car is about to be dynoed so hopefully i come out with some good numbers and hopefully i get the car tonight.
Old Oct 20, 2006 | 03:31 PM
  #67
sugarspunZ's Avatar
sugarspunZ
that is good news bro. when you get your car back we should meet up. i would love to check it out and see how an APS ST is when it is running propperly.
Old Oct 20, 2006 | 03:51 PM
  #68
spracked's Avatar
spracked
go to the sonic meet tomorrow in anaheim! i should be there with my car if everything goes smoothly
Old Oct 20, 2006 | 03:58 PM
  #69
sugarspunZ's Avatar
sugarspunZ
what time and where is it? what is the plan? just meet up and have a burger or what?
Old Oct 20, 2006 | 04:05 PM
  #70
spracked's Avatar
spracked
its in the socal section, sonic off of lemon and the 91. its at 12:00, there should be like 30+ z's.
Old Oct 20, 2006 | 05:27 PM
  #71
JoeDirtPharmD's Avatar
JoeDirtPharmD
I could've sworn you saw my car on that PCH run...
Old Oct 20, 2006 | 08:02 PM
  #72
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
OK . just did some tests on the dyno and on the road .
first. on the dyno, i had a friend look underthe car while doing a pull. the car goes to about 9 psi and drops to 7. the wastegate cracks open, and this is without wastgate pressure line connected! usually with the line disconected the car is supposed to keep rising on the boost to a much higher pressure. also, we measured the back pressure and its about 5-6psi , which is very high. so, here is the conclusion: too high a back pressure causing too high a manifold pressure, pushing the wastegate door open at load, which limits the boost as a side effect. and yes, this is after the preload on the wastegate spring is set to near-maximum. so ... this is a consequence of restrictive exhaust, only a 2.5 inch single..and on top of that, the aps adapter, brings it down to even smaller 60mm... we were hoping that it would not be bad enough to cause this problem, but 5-6psi of backpressure is just too much
final numbers: 340 hp, 379 ft-lb torque
Old Oct 20, 2006 | 08:11 PM
  #73
JoeDirtPharmD
Sam - any opinion on whether an external wastegate setup (assuming the car is coupled with an APS 2.5" exaust) would resolve the boost loss?
Old Oct 20, 2006 | 08:20 PM
  #74
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
ultimately, external wastgates are by far the most accurate when it comes to boost control. when APS comes out with their external wastgate upgrade for the ST, it would be a must for this kit.
Old Oct 20, 2006 | 08:55 PM
  #75
sugarspunZ's Avatar
sugarspunZ
you right bro. i did see it. however i didnt the pleasure of a ride in it. maybe next time.
Old Oct 20, 2006 | 08:57 PM
  #76
sugarspunZ's Avatar
sugarspunZ
spracked,
sounds like a new exhaust is in order. i sell you my aps st exhaust. or go with the big 3" aps exhaust.
Old Oct 20, 2006 | 10:29 PM
  #77
spracked's Avatar
spracked
spracked,
why are you selling it? is it on your car?
Old Oct 20, 2006 | 10:35 PM
  #78
sugarspunZ's Avatar
sugarspunZ
it is on my car yes. i want to get big daddy. i want the 3" aps exhaust. i have my plans and i think big daddy will work much better.
Old Oct 20, 2006 | 10:44 PM
  #79
spracked's Avatar
spracked
pm me what you want for it, if you are going to the meet tomorrow we can talk about it more.
Old Oct 21, 2006 | 04:47 PM
  #80
Bullitproof's Avatar
Bullitproof
definatley get the aps st exhaust. i went thru 3 exhausts (stock, fujistubo, JIC)before i finally relented and get the aps st exhaust. might be pricey to some but for this kit, it's worth it. BTW, nice numbers from Sam the tuner out there on the west coast. now get that aps exhaust and i bet you'll see a 20-25hp increase because of the better flow. the thing i like about the exhaust is that it doesnt sound louder than the fujistubo i had when i was n/a. the jic 3inch was too loud, attracting attention wherever i went. some times it was nice, but when the windows were up, i couldn't hear myself think because of the exhaust drone. with the aps exhaust, it has a nice mellow tone and actually burbles a little with the cams installed. once i hit the gas, i hear turbo and BOV for a change, which is nice. i like the stealth mode and i can blend in with all the g35's out there with a shiny exhaust.......till i hit the gas that is.
