feul tank leak
Old Oct 16, 2006 | 12:45 PM
streamz's Avatar
streamz
Default feul tank leak
hi guys im from south africa and have just done my aps tt install on my z but after fitting the fuel pump and regulator my car seems to blow the tank seal out when i refeul i have had 4 new seals and gone over the whole install and its followed exactly as per instruction .
Has anybody else experianced this or have a clue what it might be
many kind regards rob
Old Oct 29, 2006 | 10:41 AM
Shah81's Avatar
Shah81
i had the same problem. When the guy installed the oring on the gas tank some how it got some gas on it and expanded. So i went and found a oring from a place that sells orings for hydrolics. It is working good so far. dont buy a replacement oring. find one with a different material but the same size
Old Jul 10, 2007 | 07:39 PM
Abishop's Avatar
Abishop
this sounds like my problem, anyone have any ideas?
Old Jul 10, 2007 | 07:45 PM
westpak's Avatar
westpak
SFZCC
It is tough, if you are sure it is the seal (oring) try to reinstall the pump and carefully ensure the seal sits all the way around before you tighten the screws.
Best way is to push down on the pump, ensure the seal is in place and install/tighten the screws will keeping pressure on the pump to keep it from moving up and the seal getting out of place.
Old Jul 10, 2007 | 08:05 PM
Abishop's Avatar
Abishop
how do you get to this o ring?
Old Jul 10, 2007 | 08:18 PM
westpak's Avatar
westpak
SFZCC
It goes around the outer diameter of the fuel pump, when you remove the 6 or so screws holding the fuel pump in place the oring/seal is under it. The white top not the metal ring that is separate from the fuel pump once you remove the screws.
The thing is that the pump has a spring load on it so if you do not hold it down as you put the screws in it will pop up slightly and if not careful the oring/seal might not seal properly.
Old Jul 10, 2007 | 08:23 PM
Abishop's Avatar
Abishop
Do you have to drop the tank or is there an easier way to get to this pump?
Old Jul 10, 2007 | 08:28 PM
westpak's Avatar
westpak
SFZCC
No you don't, you can access it behind the passenger seat.
Open the storage compartment, remove the little mat, then remove the plastic tray and sound mat and there it is.
Old Jul 10, 2007 | 08:29 PM
Abishop's Avatar
Abishop
ohh sweet thank you, im going to check it out now.
Old Jul 10, 2007 | 08:36 PM
Abishop's Avatar
Abishop
I found the top of the pump but how do you pull off that top metal part with the 4 clips?
Old Jul 10, 2007 | 08:48 PM
westpak's Avatar
westpak
SFZCC
Ah forgot about them, just use a screw driver to turn them and that is it the cover slides over the clips.
But before doing anything with the fuel tank it is good to have it low in gas as well as relieve the pressure in the fuel system, this can be done by removing the fuel pump fuse, in the battery compartment fuse box, and crank the engine a few times until it wont start.
Old Jul 10, 2007 | 08:51 PM
Abishop's Avatar
Abishop
ha ha well i have a full tank of gas! Ill put it back and hopefully when i drive it to the dealership me and my buddy Eric can pop it off and replace anything that is bad with new o rings! Thanks again Westpak!
Old Jul 11, 2007 | 08:48 AM
Abishop's Avatar
Abishop
Well we pulled off the cover and it was pretty moist on the top of the pump. It looks like its comming from the return line because the big o ring wasn't popping out on any side (from what Eric or I could tell) Has anyone else had this return line leak on you when you have your tank full?
Old Jul 11, 2007 | 08:52 AM
westpak's Avatar
westpak
SFZCC
Not sure what return system you have but the return line may just need tightening or the nut inside the pump holding the return fitting in place may need to be tightened.
Old Jul 11, 2007 | 11:51 AM
Abishop's Avatar
Abishop
i have the return setup that comes with the APS kit.
Old Jul 11, 2007 | 12:00 PM
synth19's Avatar
synth19
Had the same problem as you described. Sounds like your oring. And yes, get your fuel down to at least 1/2 tank before you investigate or you will have a sloppy mess! Make sure you clean and dry the entire top of your fuel pump assembly and make sure you get absolutely no fuel on the oring. There has to be a better product out there that won't let it expand!
Old Jul 11, 2007 | 12:24 PM
Abishop's Avatar
Abishop
^ did you mess with it when your tank was full?
Old Jul 11, 2007 | 12:26 PM
Jason333's Avatar
Jason333
hi
When i had my TN kit put on, the mechanic put the screws in wrong. It actually punctured the tank and caused a lot of issues. In the end i had to get a new tank
He was good enough to pay for it, so no complaints on that!
I was only able to fill 1/2 of the tank up as it would leak everywhere when i tried to go over the transmission hump.
Old Jul 11, 2007 | 12:30 PM
Abishop's Avatar
Abishop
yea, i have a very small leak, it just seems to come out when my gas sloshes around...
Old Jul 11, 2007 | 12:36 PM
synth19's Avatar
synth19
not completely, but enough to have some leak when we removed the assembly.
