what vacum?
Old Oct 17, 2006 | 05:37 PM
speedlimits's Avatar
speedlimits
Default what vacum?
im reading a 15vac@idle on my boost gauge with vortech sc
is that fine? i heard other ppl having 20vac@idle..
Old Oct 17, 2006 | 07:28 PM
QuadCam's Avatar
QuadCam
My idle is 18-20 mmHG. you might have a leak somewhere.
Old Oct 17, 2006 | 07:39 PM
Eazzy's Avatar
Eazzy
I dont know the elevation of where u are in AZ.
Vacuum is 22" HG max. at sea level only. At 5000 ft it drops to 17 max, at 8000 its round 14 max.
If ur way up in the Rockies---It will drop to 14.
Use that as an initial guide line---Then start looking for leaks
Old Oct 17, 2006 | 07:47 PM
Eazzy's Avatar
Eazzy
Well Phoenix is only 1100 ft ----always chk ur boost gage Vacuum with a Shop Vac Gage and also use a shop gage to chk when u tighten up potential leaks
Old Oct 17, 2006 | 10:02 PM
phunk's Avatar
phunk
CJ Motorsports
I think I used to get 18 when I had stock engine. Now with the cams I think its usually around 16.
Old Oct 17, 2006 | 11:01 PM
Eazzy's Avatar
Eazzy
Overlap on some cams will drop it a little on the Z---It used to be much worse with the more radical V8s--- A vacuum canister would generally fix that to operate brakes and Vac devices. It wont hurt him to do some checks--I was running a strong 18 with my Vortech here in Tx. ---Timing will drop it also---If u are SURE u have no leaks---Have ur tuner Play with ur Split Second
Old Oct 18, 2006 | 04:41 AM
booger's Avatar
booger
nismo cams.....11 to 13 at idle . 1,000 ft above sea level
zyou8er
Apr 7, 2015 03:39 PM
Synjn
Jun 25, 2010 03:50 AM
thebuffalo11
Sep 20, 2009 05:49 AM
chopperman
Dec 29, 2008 08:15 PM
q8pianist
Dec 6, 2006 04:16 PM
