Greddy Twin
Old Oct 21, 2006 | 02:31 PM
electricmarquis's Avatar
electricmarquis
Default Greddy Twin
Has anyone installed the greddy twin kit as it comes from greddy and the intercooler. Alot of speed shops around here dont like the greddy kit they say it doesnt fit very well. They also say its not complete and if you run it like they sell it with preprogrammed emanage you will eventualy blow your motor.
The speed shops tell me that its designed so someone can install it and drive it slowly to a dyno tunner for final touches.
Old Oct 21, 2006 | 02:41 PM
Julian@MRC's Avatar
Julian@MRC
That is somewhat truthfull, and somewhat innacurate at the same time..
JETPILOT's Avatar
JETPILOT
Post this in the forced induction forum. That's where you will get the best advice.
I agree with most of the advice your shop gave you. The kit fits fine. The advice on the tuning is good. The kit needs to be tuned or you will likely blow your motor. You would benefit from a better ecu solution than the Emanage Blue such as a UTEC. A TurboXS UTEC with a good tune with a Greddy kit is a great combo for some big power.
JET
Old Oct 21, 2006 | 04:45 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Yup, its a timebomb, straight out of the box. With the right upgrades and tuning, is actually a superb kit....especially for higher boost applications. Still very good at low boost too.
Old Dec 26, 2006 | 07:41 AM
trashcan's Avatar
trashcan
Old thread, sorry.
Can you please explain exactly what parts absolutely have to be upgraded to run this kit on a completely stock Z at standard boost?
Old Dec 26, 2006 | 08:12 AM
Juztin's Avatar
Juztin
throw out the EM for a UTEC, or something of the like.
Old Dec 26, 2006 | 08:15 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
UTEC w/tune and a return fuel system will get it a lot safer
Old Dec 26, 2006 | 09:45 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by trashcan
Old thread, sorry.
At the standard 5.6psi I would do a UTEC w/Tuner Reg, Walbro Fuel Pump (RFS not needed at 5.6psi but certainly doesnt hurt), 1 step colder plugs, and some aftermarket exhaust. A 2.5" TD would be nice, and some test-pipes to really free up power. Also I hope it goes without mentioning you would need guages. And likely a clutch/fw, and hopefully some better tires for traction and brakes for slowing your speeding **** down
If your planning on big (500+whp) later you could just spend big bucks now on a 3" downpipe set with a TD 3" exhaust, heavier duty clutch/fw and sell the standard 440cc injectors for 550+cc, and add a fuel system, possibly bolt-ons like a plenum/spacer, ignition, etc, etc....
Old Jan 6, 2007 | 01:15 AM
silver nismo's Avatar
silver nismo
I beg to differ 100% right u need to know ur aim,goal,whp... and then start building the Greddy TT is a great kit but if ur aiming to run it as is with the emanage-blue u r verey safe with 300 whp just with a good tune... if ur aiming more then u need the mentioned above... good luck..
Old Jan 6, 2007 | 05:02 AM
captj3's Avatar
captj3
But you still need the autosport harness and the other piece ( I forgot the name ) to control the timing and a fuel pump. This would be the minimum to run this kit at stock psi.
Old Jan 6, 2007 | 07:00 AM
phunk's Avatar
phunk
CJ Motorsports
greddy kit with a UTEC or emanage ultimate and a return fuel system and professional tuning by an experienced turbo VQ tuner will result in your best chance of reliability and between 400-470rwhp depending on the level of risk you are willing to assume. You will need to add your own blow off valve and boost controller. If you want to run stock boost, with proper install it can be very reliable and should make around 360-370rwhp.
sales@czp
Sep 23, 2019 03:30 PM
gc350z03
Oct 28, 2016 05:00 PM
