Anyone here with a JWT TT and a diff BOV???
Old Oct 24, 2006 | 10:21 AM
NoahzBurnt's Avatar
NoahzBurnt
Default Anyone here with a JWT TT and a diff BOV???
I had the TurboSmart dual port on my car but it turned out to be defective. I am back on the bosch unit that is supplied with the kit but I cannot stand the way it sounds. I want a nice BOV but am worried about getting into stalling issues and B/S again. Is anyone running a BOV other than the BOSCH and have you had any issues?
Old Oct 24, 2006 | 10:23 AM
MIAPLAYA's Avatar
MIAPLAYA
If the car is tuned and setup for a re-circulated BOV you should be able to use any unit as long it can be re-circulated. Although if you want it to vent to atmosphere it shouldn't be terribly hard to tune it the momentary rich condition when the system blows off.
Old Oct 24, 2006 | 11:06 AM
NoahzBurnt's Avatar
NoahzBurnt
I figured that but my main concern is the stalling and sudden RPM dropping that I just spent over $1000 to to fix. I am trying to dump atmospherically BTW
Old Oct 24, 2006 | 11:11 AM
MIAPLAYA's Avatar
MIAPLAYA
I see. Well in that case you are going to need something to compensate for the temporary rich condition caused by the metered air being vented to atmosphere. I don't know if the Split Second can be tuned for this. I believe the Apexi S-AFC2 had a correction built in for that but its been a while since I read up on it.
Old Oct 24, 2006 | 11:18 AM
QuadCam's Avatar
QuadCam
as long as you can adjust the preload on your BOV so that it is sealed up when it has vaccum, you'll be fine venting to atmosphere.
I have done it on vorteched mustangs in the past. I used the greddy type-s. and these mustangs had the MAF on the inlet side of the blower. There were no drivability issues at all!!! The only time the BOV would open up is when there was pressure in the pipes AND vaccum in the manifold...basically when youd let off the throttle immediately after boosting. while cruising, there was no problem.
also, you could rework the piping on the JWT kit so that the MAF is located after the turbos.
Old Oct 24, 2006 | 11:31 AM
k3silk's Avatar
k3silk
I have the HKS on mine and have no stalling problems at all
Old Oct 24, 2006 | 11:43 AM
dutchboy's Avatar
dutchboy
Same here, except on a V6 Eclipse. Worked like a charm and was easily adjustable.
Old Oct 24, 2006 | 11:48 AM
Mike Wazowski's Avatar
Mike Wazowski
post some pics man...
Old Oct 24, 2006 | 11:55 AM
chimmike's Avatar
chimmike
you paid $1000 essentially so you could vent to atmosphere? Wow.
try a different bov.......greddy type RS, etc.
Old Oct 24, 2006 | 11:59 AM
Mike Wazowski
he paid $1000.00 to get his car fixed. not vent to the atmosphere.
Old Oct 24, 2006 | 12:06 PM
chimmike's Avatar
chimmike
look. He paid $1000 to fix symptoms that are brought on by venting to atmosphere on a setup essentially meant to be recirc'd.
so he can find a BOV that is still loud and recirc it, or risk having the same issues again. His turbosmart BOV was the issue causing the stalling/rpm drops from sudden off throttle conditions. Classic results.
Greddy type RS or HKS SSQ can be recirc'd. I like the Forge 007 diverter valves too. They look great and are easy to recirc, and sound great too.
the turbonetics raptor can be recirc'd as well.
If his BOV is between the MAF and the TB, he's got to recirc or he'll still have those issues. been there, done that, on 2 other Nissans. That's just how it works. If between MAF and TB, while in vacuum, BOV=open=losing air. MAF says "x" air is going into engine...and when "x" air isn't, but "y" air is, it throws the car off and either stalls or drops rpm heavily.
Old Oct 24, 2006 | 12:20 PM
QuadCam's Avatar
QuadCam
It can be done. I had no probs with it on my vortech'd cobra. Like I said above, the greddy type worked on my setup.
Looking at the the TN raptor, I doubt it'd work for that set up. My raptor opens up with any vaccum. At idle, the BOV is sucking air into the engine. makes me think I need to put a filter on the end of the BOV.
Old Oct 24, 2006 | 12:32 PM
chimmike's Avatar
chimmike
all BOVs open at vacuum. The Raptor has a fitting that allows it to be recirc'd.
Of course open atmosphere venting can be done, but there are certain BOVs that allow it. I'm guessing that turbosmart isn't one of 'em.
I mentioned the greddy type RS. I know the HSK SSQ has a fitting that can allow it to be recirc'd...........but the greddy can be tightened enough to allow it, but you've got to watch out for compressor surge/flutter from it being too tight.
Recircing has more benefits than detractors though........i think the only detractor for recircing is sound (but the damn greddy RS is loud as hell recirc'd too LOL!)
Old Oct 24, 2006 | 01:58 PM
taurran's Avatar
taurran
Damn Mike. It's not about how well it works or good it sounds. It's about being JDM.
Old Oct 24, 2006 | 02:03 PM
chimmike's Avatar
chimmike
forgive me........I forgot that form>function again
QuadCam's Avatar
QuadCam
he needs a BOV that you can adjust the preload enough so that it takes more than just vaccum to open it up. it needs to see vaccum from the manifold AND pressure in the pipes.
If he does this, he won't have the stalling issues that other people get.
Old Oct 24, 2006 | 02:08 PM
chimmike's Avatar
chimmike
yup, but then he'll get surge/flutter issues..................that's just how it works when the BOV is placed between the MAF and TB
Old Oct 24, 2006 | 04:39 PM
k3silk's Avatar
k3silk
I dont have any pics because it is behind the bumper if you want to know how to do it call vrt i used the hks bov and blocked off the other ports.
Old Oct 24, 2006 | 04:48 PM
MIAPLAYA's Avatar
MIAPLAYA
Actually if you connect a pressure signal to the bottom port of the Raptor BOV AS WELL as leaving the current port connected I believe the Raptor BOV will stay closed under vacuum.
Old Oct 24, 2006 | 07:17 PM
QuadCam's Avatar
QuadCam
How would that work under boost?
