Turbonetics Turbo Seal Leaking AGAIN !!!! (3rd Turbo)
Old Nov 21, 2006 | 10:13 PM
  #121
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by redline350ZZ
My oil pressure gets high as well but its always been like that (Pre-FI)
Is it like that all the time? I'll admit my oil pressure is high when I first start the car and its cold. But once the car is warmed up I never see oil pressure approaching those numbers at those times.
Old Nov 21, 2006 | 10:25 PM
  #122
redline350ZZ's Avatar
redline350ZZ
My car is kinda OOC right now until I get a Built motor from Santa so I cant answer that specifically all I know is that I would warm up at about 45 and under WOT be in the 80 area.
Old Nov 21, 2006 | 10:32 PM
  #123
JETPILOT's Avatar
JETPILOT
I talked with Sharif about the problem, and he said he had seen a few break off as well.
Redline.... is your turbo leaking oil as well?
JET
Old Nov 21, 2006 | 10:34 PM
  #124
MIAPLAYA's Avatar
MIAPLAYA
JET
I guess I'll ask Sharif about it then. If Sharif didn't post it and no one else did theres no way for me to know about it.
As for the oil pressure, what weight oil are you running? Same to you redline. I've run 5W-30, 10W30, and 15W30 and my oil pressure has never changed...
Old Nov 21, 2006 | 10:36 PM
  #125
JETPILOT's Avatar
JETPILOT
I don't know what weight Sharif put in.
JET
Old Nov 21, 2006 | 10:38 PM
  #126
MIAPLAYA's Avatar
MIAPLAYA
JET
I'll ask Sharif about that too tomorrow. If the weight was too much it would cause excessively high oil pressure which would murder seals all day long...
Old Nov 21, 2006 | 11:41 PM
  #127
IIQuickSilverII's Avatar
IIQuickSilverII
i use 10w30 full synthetic...
and yo Jet, realx man, no need to see you and turran take "jabs" at each other... its pointless... I think we are all away for your problems but i have rearly seen any trouble with turbonetics kit at all, but here on the forums, specially since you are pretty known, when someone post something everybody seems to jump on things really quick and make conclusions real fast, so its fair what turrans said. You got the turbo at turbonetics and they are looking at it and we are all here trying to help you, even with my limited knowledge i am trowing ideas and hopin for the best for you man, no need to get mad and start the bashing game, when tons of other users have had no problems with this kit at all, cuase you know how this forums work...they are a bunch of sheeps here, they jsut follow.
Old Nov 22, 2006 | 04:07 AM
  #128
captj3's Avatar
captj3
Mia, just for some more info. When I start my car my oil pressure is 100-120. After it warms up wot 60-70 psi at idle 15-20 psi. I run 10/40 now and ran 5/30 before FI with the same results. These readings are from the stock gauge non rev motor.
Old Nov 22, 2006 | 07:06 AM
  #129
QuadCam's Avatar
QuadCam
you guys have an oil pressure gauge from the factory on the Z? there's nothing on the G.
Old Nov 22, 2006 | 07:11 AM
  #130
QuadCam's Avatar
QuadCam
As far as I know, my up-pipe is fine. I saw the broken one at Forged Perf. I guess that was Jet's. IIRC, all 3 tabs were gone and when they broke off, it left (3) 1.5" long openings in the pipe.
Old Nov 22, 2006 | 07:18 AM
  #131
MIAPLAYA's Avatar
MIAPLAYA
Ditto thats EXACTLY what I see..
  #132
MIAPLAYA's Avatar
MIAPLAYA
Yeah its factory on the Z...
Old Nov 22, 2006 | 07:20 AM
  #133
MIAPLAYA's Avatar
MIAPLAYA
OK so we are back to Jets car as the only one I have heard about. Could the added weight on the Turbosmart 48 have caused it? The pipe wasn't designed to be cut, welded, and have a 48mm wastegate hung off it.... I'm not saying thats the cause but its possible...
Old Nov 22, 2006 | 09:33 AM
  #134
QuadCam's Avatar
QuadCam
for some reason, I think jet has the wastegate mounted to the "Y" pipe, not the up-pipe. I remember see pics online, and I thought he had an extension welded onto the "y" pipe. I could be totally wrong though!. :-)
Old Nov 22, 2006 | 09:52 AM
  #135
JETPILOT's Avatar
JETPILOT
I have the wastegate mounted to the y-pipe. No that wasn't my pipe at Forged. I removed the kit here at my house and only sent him the good up-pipe.
JET
Old Nov 22, 2006 | 10:03 AM
  #136
MIAPLAYA's Avatar
MIAPLAYA
I see...well I don't really know what it could be honestly. Like I said this is the first time i hear of it. I guess i'll have to crawl under the car and see what potential reasons there are...
Old Nov 22, 2006 | 11:24 AM
  #137
IIQuickSilverII
all its jstu plain weird
Old Nov 22, 2006 | 01:34 PM
  #138
taurran's Avatar
taurran
Its an aftermarket FI car. Sh*t breaks. I'm surprised we aren't all used to it by now (even though mine never breaks).
Old Nov 22, 2006 | 01:57 PM
  #139
IIQuickSilverII
yah... i hear you but what i mean by weird is that what his problems are nothing of the usual stuff
Old Nov 22, 2006 | 05:37 PM
  #140
JETPILOT's Avatar
JETPILOT
MIA... were you able to talk to anyone today about switching to a smaller oil line and fitting?
Thanks
JET
