FI guru's HELP!
Old Oct 31, 2006 | 08:42 PM
chichi506's Avatar
chichi506
Default FI guru's HELP!
while i was on my way to get gas, i was driving normally with the heater on full blast. as soon as i stop at the gas station i notice that my engine temperature starts getting a little higher, and my heater is not as hot anymore. i wait for about 30 more seconds to see if the temperature would subside, but it just kept climbing. so i turn off the car immediately and get out. i noticed that a whole bunch of coolant is spilled all over the place! so i wait for a couple minutes to let the car cool down and add a little bit of coolant. but the funny thing is that i didn't have to add that much, but it looked like i spilled a whole bunch. i drive as slow as possible to get the car home and avoid getting it towed and the temperature of the car stabalizes. as soon as i get home, i run a test to see if the heater will work and it works just fine. temperature fine, no coolant leaking. but i'm afraid to drive it now ever since that happened. My dad is more informed about cars then i am and says it may be the thermostat. Can anyone please give me information as to why my car is doing this? what do you guys suspect the problem is? any information is greatly appreciated. thanks alot guys!
Old Oct 31, 2006 | 08:43 PM
redline350ZZ's Avatar
redline350ZZ
Head Gasket go boom???
I C built motor..U know where the coolant was coming from?
Old Oct 31, 2006 | 08:44 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Sounds like the thermostat stuck for a little but.
Old Oct 31, 2006 | 08:46 PM
chichi506's Avatar
chichi506
coolant was coming from the side where the overflow is located. it was relocated i think because of the APS kit. it wasn't coming from anywhere near the engine. any thoughts?
Old Oct 31, 2006 | 10:58 PM
silver nismo's Avatar
silver nismo
+1
Old Oct 31, 2006 | 11:01 PM
chichi506's Avatar
chichi506
Even if there was a bunch of coolant on the floor?
Old Nov 1, 2006 | 04:30 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Maybe air in the system "purge it".
Old Nov 1, 2006 | 06:52 AM
roncfpz's Avatar
roncfpz
I would bleed the coolant system and see how it runs thereafter. You may want to take it back to your tuner to be on the safe side and possibly rule out headlift or blown hg. Good luck!
Old Nov 1, 2006 | 07:18 AM
THE TECH's Avatar
THE TECH
+1 on the coolant purge.
Old Nov 1, 2006 | 09:34 AM
chichi506's Avatar
chichi506
well called zcargarage and rob wasn't there, he's at sema. but heard from vince that it's just probably air in the system. either that or the thermostat got stuck. i asked if it was a headgasket and he said most likely not beacuse the stock headgasket can take alot of abuse before something usually happens. can someone explain to me what detonation sounds like?
Old Nov 1, 2006 | 10:26 AM
chichi506's Avatar
chichi506
if it was the headgasket, wouldn't the oil from the dipstick be this creamy color, like coffee with creamer in it or something to that effect?
Old Nov 1, 2006 | 11:26 AM
kzanard's Avatar
kzanard
I am no expert, but I think if it was a catastrophic head gasket failure, then yes, there would be coolant in the oil. However, if it is momentary head lift due to detonation, I do not believe you would see any measurable coolant in the oil. This could also introduce a burp into the cooling system, which could effect the heater and the overheat condition.
Old Nov 1, 2006 | 12:15 PM
roncfpz's Avatar
roncfpz
+1, perhaps change the oil and analyze to be safe.
Old Nov 1, 2006 | 12:29 PM
chichi506's Avatar
chichi506
ok, will do guys, but if the oil is the normal color and the coolant that spilled was only on the side where the resevoir was, then that probably mean that it was just something minor right? sorry, but i'm really stressed out right now, just need some assurance, that's all
Sk8fe
Mar 26, 2006 11:06 AM
GodZilla
Photoshop
Dec 16, 2005 02:45 PM
Sexy350zStud03
Cleaning & Detailing
Oct 13, 2005 04:18 AM
