Vortech Guru's...pls see if you can lend some advice!
Old Nov 2, 2006 | 08:06 AM
deanG35c6's Avatar
deanG35c6
I would go with the obvious first and check the BOV and the Intercooler for leaks under pressure.
Old Nov 2, 2006 | 08:18 AM
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by MRC Motorsports
Guys, this has nothing to do with the issue he is experiencing..His situation is purely mechanical,IE boost leak or belt slippage..There are no electronics involved in the operation of the Supercharger itself.
Todd have you jsut tryed to put the stock intake manifold back on instead of the kinetics?
Old Nov 2, 2006 | 08:52 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
SS Box is out..UTEC in..this was happening before I swapped the UTEC and still is after the UTEC..again, this is machanical as MRC is saying..not engine management wise...
Thanks for all the imput guys, these are all things I have been throwing around in my head as well, I like to hear everyone else's imput!!!
TODD
Originally Posted by jpc350z
Another possibility is the S.S Box is not operating properly...cam signal, crank signal Maf signal, ground lost ???
Old Nov 2, 2006 | 08:54 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Talking
No way should you be able to close the valve with pressure from your mouth..I would check the spring and diaphram inside it..You would never be able to blow or suck hardenough on a vacume line to make that bypass valve close..Unless your VERY talented..
we are very talented (wait a second, that sounds bad )
no really, the BOV responded to sucking pressure from the mouthal region
I'm gonna dive in deeper and figure it out, just figured that in the meanwhile, while not able to work on it today, I'd get all of your feedback for the battle tomorrow!
Thanks MRC, appreciate all of your feedback!
-TODD
Old Nov 2, 2006 | 10:30 AM
booger's Avatar
booger
Talking
Here is the pipe i made to test for preasure leaks . I hook it up right before the BOV. Works great !
Attached Thumbnails Vortech Guru's...pls see if you can lend some advice!-p9070015-small-.jpg
Old Nov 2, 2006 | 10:43 AM
kevinapex's Avatar
kevinapex
Is that a weapon of mass distruction?!
Old Nov 2, 2006 | 10:50 AM
IIQuickSilverII
good one
Old Nov 2, 2006 | 11:55 AM
Barzten1's Avatar
Barzten1
Hey Todd my stock manifold is burried somewhere in my garage from the move. I don't think it could be the SSV after its been working fine for over a year. Did you get a chance to swap the plugs. I should have brought it home so I could change them. Also it seems like its boosting up high because I kept up with that turbo G. The bogging is only down low.
Old Nov 2, 2006 | 01:31 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Jason, I am virtually smacking you in the face It is NOT THE PLUGS!!!
It is not building boost!!!! Your Defi, worn out boost gauge spikes and jumps up to 4psi when it tries to boost, but when monitoring on the much more accurate MAP sensor while datalogging with the UTEC, it makes a whopping 0.7psi..this is not a plug problem (I will chnage them as well after the boost issue is figured out, I havent had a chance to get over to the shop today, but planning on it tonight)
Call me and let me know if you work tonight
-TODD
Old Nov 2, 2006 | 02:33 PM
Barzten1's Avatar
Barzten1
Hey why did you hit me??? LOL I'm totally free tonight.
Old Nov 2, 2006 | 02:51 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
so you just allow full pressure to rush through the system? I was thinking of hooking up a valve that I could adjust how much pressure was introduced into the system, but great tool nonetheless! thanks for sharing..looks dangerous
I assume you just attach it with a silicone hose and a hose clamp?
Old Nov 2, 2006 | 02:58 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
is that 2 1/2" diameter?
Old Nov 2, 2006 | 03:56 PM
Julian@MRC's Avatar
Julian@MRC
Have you taken off the mains serpentine belt and hit all the pulleys with some sand paper?The belt sounds like it is slipping to me..Try that first..That F'er has to be pretty tight..
Old Nov 2, 2006 | 04:04 PM
Barzten1's Avatar
Barzten1
I was thinking about swaping that too but the car was running rich as hell and smelled like unburnt fuel.
Old Nov 2, 2006 | 04:09 PM
Julian@MRC's Avatar
Julian@MRC
Thats probably because the SS box dumping fuel based on RPM and the boost that is normally there, is not there now, cause your belt is slipping or your leaking boost..
Old Nov 2, 2006 | 04:16 PM
Barzten1's Avatar
Barzten1
ahhhhh.....I'm early in the learning process and am greatfull for Todds help and all your guys reponses. Were going to tackle it again here in an hour. Thanks MRC Motorsports!
Old Nov 2, 2006 | 04:45 PM
Julian@MRC's Avatar
Julian@MRC
Yup, seems like we know the fix for alot of stuff, since we have experienced it all on our own cars..Problem is, we never get enough praise on these boards..guess we need to get a crew of Nutswingers to start a big thanks thread every time we answer a phonecall.. Like some other sponsors..
Old Nov 2, 2006 | 10:07 PM
  #38
ForceInduction's Avatar
ForceInduction
Originally Posted by 350zDCalb
Yes, I realize that, we had puled the BOV off before and inspected it, when I alpied pressure to the BOV nipple (with my mouth blowing) , the valve closed, the action was smooth...no cause for alarm here
-TODD
With the Vortech Bypass Valve it should be closed if you pull it off. If you suck on the vacuum tube on top it will then open.
So if you are saying that you blew into it and it closed then this is your problem. Cause the bypass should be closed if nothing is hooked up to it.
If you don't feel its the bypass you might want to check your fuel pressure. If you are running to rich or lean it will cause you not to be able to build up boost.
Old Nov 3, 2006 | 05:00 AM
  #39
kevinapex's Avatar
kevinapex
Todd, I know you said the bov is working through mouthal stumli, can you pull the vacuum line off the bov, and see if it is even sending the correct amount of vacuum or not to the bov under throttle on and throttle off?
Old Nov 3, 2006 | 05:37 AM
  #40
350zDCalb's Avatar
350zDCalb
builtZmotors
i pulled the vacuum line off, stil did not build boost
